  • Guests: 40
09/13 WarrenR (64)
09/13 currentkills91 (32)
09/14 Proud Mary (62)
connecting HV cables
John
Sat Mar 18 2006, 07:56PM Print
John Registered Member #327 Joined: Sat Mar 18 2006, 07:47PM
I'm looking for a proper method for inter-connecting HV cable.
The outside diam. of the cable is 3.5 mm. Where can i find some splices, rated for 30 KV ?
Sat Mar 18 2006, 08:36PM
A couple of layers of heat-shrink tubing should do.
Sat Mar 18 2006, 11:00PM
Actually it depends on how you are running the wire. If you are running this splice by ground or close to a something it can easily discharge to, then thats probably not good enough. Remember, a splice will add considerable field stress to the area and allow arcing to occur more readily.
Hazmatt_(The Underdog)
Sun Mar 19 2006, 09:21AM
How about getting a long length of oversized heatshrink, shrinking it down at the very end long before the splice, injecting silicone or potting compound/potting epoxy, then shrink the other extreme end.
I know 3M sells similar epoxy/heat shrink and epoxy/cold shrink for HV, so this might be okay. If you're still concerned I would do a dielectric HiPot test with a flyback.
Michael W.
Sun Mar 19 2006, 03:32PM
Michael W. Registered Member #50 Joined: Thu Feb 09 2006, 04:07AM
I had that happen, at a splice that was just covered in lots of tape, it was near a powerbar mounted on my coil, it arced to the ground and the powerbar exploded quite violently....
GimpyJoe
Sun Mar 19 2006, 04:34PM
My favorite way to make good insulated splices is to slide a piece of vinyl tubing over the wire and then solder the connection. Then I make a glob of hot glue on the connection and the surrounding area and slide the tube down over it while the glue is hot.
