  • Guests: 59
01/12 RoV IW3IPD (63)
Van De graff Toroid
Michael W.
Mon Mar 20 2006, 05:35AM Print
Michael W. Registered Member #50 Joined: Thu Feb 09 2006, 04:07AM
What would be the best way for a DIY van de graff spherical toroid? Opening in bottom, hollow inside....quite a bit of a puzzle...
Mon Mar 20 2006, 11:16AM
How about a (smooth) TC-type toroid
with an upside-down stainless steel salad bowl (etc) on top?
Mon Mar 20 2006, 12:58PM
If you have smooth toroids, you can use a few stacked as collector . I think it would work.
GimpyJoe
Mon Mar 20 2006, 01:38PM
The best things I have found are plastic globes that go over lights. They are indestructible, cheap, and fit perfectly on standard PVC sizes. All you have to do is cover them in al. tape and smooth it completely with the back of a spoon.
Mon Mar 20 2006, 05:42PM
For a VDG, a sphere is the best bet. Remember, that the maximum voltage on a toroid is dictated by the outer radius, and for a VDG, you want to maximize voltage. You really don't need much field control as toroids provide for tesla coils.
You can also try going to a local salvage yard to find some unique objects to make large spheres from. That being said, NY Science First sells a very nice aluminum spun 18" sphere for about $100.00 - well worth the money.
