  • Guests: 463
GhostlyFigures (36)
10/06 Ivan Kalafatic (17)
10/07 Pyromaniac (34)
10/07 Wavetuner (76)
Big Red. The Coil (now with 1st light pics)
1 2 3 4  last
teslacoolguy
Sat Jun 21 2008, 05:26AM Print
This is my current project that is taking up almost all of my time during the day. It is a big sgtc that is going to be powered by a quad mot bank running from 220v. I am expecting it to produce around 7' streamers when it is completed and tuned.
Here are some pictures of my progress.
Secondary 32" tall on a 6" pvc form wound with 24awg magnet wire:
1214025295 1107 FT0 Dscn2853
MMC Capacitor bank 60x 942c16p33k:
1214025432 1107 FT0 Dscn2799
1214025432 1107 FT0 Dscn2800
1214025432 1107 FT0 Dscn2801
Power Supply 4 1200W mot's:
1214025530 1107 FT0 Dscn2832
1214025531 1107 FT0 Dscn2835
Im getting my variac tomorrow and i have copper tubing and plexiglass ordered for the primary so more will be added shortly
J. Aaron Holmes
Sat Jun 21 2008, 04:29PM
Hey there, TCG: Nice work so far! The MOT bank is looking pretty evil with those big bushings!! cheesey What are you thinking of for a spark gap? A simple "leaf blower" or "sucker" gap (or some other air-blast type) would work fine at 2.5-3kVA, but probably not so well at MOT bank voltages. I'm a little surprised not to see you using your pole pig, actually. I think that would probably make your life loads easier.
Cheers,
Aaron, N7OE
teslacoolguy
Sat Jun 21 2008, 11:22PM
I got my 90A variac today so tomorrow i will be hooking that up to the mot bank.
1214090557 1107 FT47960 Dscn2865
Ken M.
Sun Jun 22 2008, 01:34AM
Haha nice over sized Variac looking forward to its completion and some pics.
teslacoolguy
Sun Jun 22 2008, 06:33PM
Today i dug up some 8 AWG wire so i am starting to build the controller setup.
Firefox
Sun Jun 22 2008, 06:45PM
Firefox Registered Member #1389 Joined: Thu Mar 13 2008, 12:50AM
Man, you are so lucky to have such understanding parents, and apparently your dad is as excited about your stuff as you are. I think I would be shot on sight for thinking about 7' long lightning bolts. My mom had a heart attack from freaking MOT arcs from a 3' PVC chicken stick.
As for the coil, she's beautiful. I love the variac too, where the heck did you get that thing?
Marko
Sun Jun 22 2008, 07:37PM
I think some people had these capacitors fail due to bleeder resistors touching their skin and causing arcover.
Bleeders should be mounted few millimeters away from the capacitors to prevent this from happening, and it's good to put some barrier in between, at least some heatshrink or PVC tubing.
Apart from that, bleeders across each cap may be overkill. Just a single resistor across entire bank is more than fien to discharge it.
About the layout of your MMC, you don't consider impractical to have such an amount of capacitors all on a single plane if it is going to be mounted into coil?
Keep the work up,
Marko
teslacoolguy
Mon Jun 23 2008, 12:01AM
Well the bleeder resistors are under the 1/4" plexi so i dont think that will be any problem at all. The capacitor bank will be mounted on the coil but i still have plenty of room to put the rsg and safety gap so it will not be a problem.
I got it at HGR Industrial surplus Link2 for $99 and seeing that they are located 30 min from were i live i was able to pick it up and not have to pay for any shipping.
teslacoolguy
Wed Jun 25 2008, 02:22AM
Double post, i know but it has been a couple days. Anyway it made the toroid today and it has a capacitence of around 27pf.
1214360517 1107 FT47960 Dscn2882
teslacoolguy
Sat Jun 28 2008, 03:58AM
Today i made the primary along with the secondary end caps and the topload standoff.
1214625504 1107 FT47960 Primary
1214625504 1107 FT47960 End Caps And Standoff
1214625504 1107 FT47960 Current Coil
1 2 3 4  last
