  • Guests: 21
Ivan Kalafatic (17)
10/07 Pyromaniac (34)
10/07 Wavetuner (76)
10/07 jeffomatic (75)
New Class e sstc.
Tue Aug 12 2008, 05:51PM Print
I figured like the 833C vttc thread, i would start this before i even started the building of it.
It uses a current transformer, 74hc14, ucc37321 and a mosfet. I have the ucc's coming(2 ucc37322 and 3 ucc37321) as well as 5, 22 amp 500 volt mosfets and 3 74hc14's.
I am also going to include the interrupter. Primary will be with 12 gauge primary wire(it will be blue just so you know :P) and secondary will be the same that will will be used for the 833c vttc(i HATE making secondaries). The ic power supply will be a 12 volt transformer with two regulators, one 12 volt and the other is 5 volts(for the 74hc14).
Here is the schematic for the sstc:
E Sstc
Shaun
Tue Aug 12 2008, 07:37PM
Whats the purpose of the 10K resistor from the feedback section to the interrupter output?
Tue Aug 12 2008, 08:27PM
Well this isn't my schematic... I found it on youtube :P. Umm i suppose to start the oscillation is what it looks like. But i figure 10k would give to strong a signal for the CT to overpower it.... Hmmm idk but the schematic worked for the guy who made it.
MRacerxdl
Tue Aug 12 2008, 10:55PM
About the Mosfet Driver, dont use the Inverting Drivers, because if fails to start to oscilate, it gets the mosfet get at High Level and shorts the power supply with the primary.
Dr. SSTC
Wed Aug 13 2008, 01:32AM
Dr. SSTC Registered Member #1407 Joined: Fri Mar 21 2008, 07:09AM
Arcstarter wrote ...
arc starter could you provide us the link for this sstc
Wed Aug 13 2008, 03:22AM
Dr.Volt wrote ...
Yes, of course.
And i now am going to make steve wards mini sstc after this. But first i want this project to be finished to see what i can do with class e.
Dr. SSTC
Wed Aug 13 2008, 06:29AM
Yes, of course.
wow thats better than i expected, cant wait to see your version
make sure you put a video of it on youtube smile
Sat Aug 16 2008, 07:30PM
I am going to have to put this project on hold mad . The place i got the components from sent them in the wrong package. The ucc's where in soic which i could easily get around by using a soic to 8 pin dip adapter. But the 74hc14 came in tssop which is TINY!!!! Smaller than a fingernail.... So i need money until i can continue this project.
Sat Aug 16 2008, 10:37PM
Just a little question, anyone know what program that circuit was drawn in?
flannelhead
Sun Aug 17 2008, 07:39AM
I suppose one 74HC14 doesn't cost that much... Anyway nice to see one of those simple-yet-effective designs again.
Mestre Racerxdl wrote ...
In fact there's an inverter gate (74HC14) before the inverting mosfet driver, so if the circuit fails to oscillate, the mosfet will stay off. Another, noticed the 10K resistor between the interrupter (555) output and the 74HC14 input? I suppose it's there to give a starting pulse to the circuit to make it oscillating. That's actually very clever and I like this schematic a lot because of its simplicity and reliability.
Arcstarter, hope you get your coil working! smile
