  • Guests: 44
ETG
Gunner
Thu Jun 19 2008, 08:50AM Print
Gunner Registered Member #1397 Joined: Mon Mar 17 2008, 12:47PM
Have you heard about Electrothermal guns? You cant find much about Google from that but Im wondering what is their effiency? At first prototype I will use 300-500J capbank and my goal is get out at least 10Joules...I will be back when I get the parts!:P
Hon1nbo
Thu Jun 19 2008, 02:28PM
check powerlabs.org as the guy there has built one, but this it is not as documented as his other college/sponsored things... but may still be useful, particularly the barrel and ignition information...
Bjørn
Thu Jun 19 2008, 04:21PM
The efficiency can in theory be very high because of the high temperatures possible. Link2 How high depends on a lot of factors.
35% seems to be quite easy to reach for much higher energies than you plan to use, so your required 2.5% seems realistic.
ea6b607
Thu Jun 19 2008, 04:50PM
ea6b607 Registered Member #1320 Joined: Sat Feb 16 2008, 01:31AM
they need to be somewhat high voltages to get a consistent spark. You probably won't be able to do this with photoflash or lytics. Best bet is a 5kdv or better maxwell.
Lomy
Thu Jun 19 2008, 05:32PM
Lomy Registered Member #789 Joined: Sun May 20 2007, 09:32AM
everyting is possible =)
my youtube channel : Link2
low voltage is better, more current is important (if u make a discharge through air)
my etgs are hv triggered and are reaching up to 6& effi
(...power lab built a etcg no etg ... =) and a etcg needs high voltage)
and at least a lil pic of a gun im building : Link2
Hon1nbo
Thu Jun 19 2008, 10:23PM
Lomy wrote ...
on the page it says the gun was designed for both etg and etcg, unless you think he was wrong, but if for some reason his "goals" section where he says he wanted to build an [etg that is also a etcg] is miswritten then my mistake
ea6b607
Thu Jun 19 2008, 11:29PM
Never realized you could make one with such low energy and still have decent efficiency. Is it really as simple as just discharging in a tube? also, when you say hv triggered are you saying you just use a low current hv arc (such as NST or marx/whatnot) and the the arc serves as the conduit for the high current. Pretty ingenious and simple.
LarsE
Fri Jun 20 2008, 04:50PM
LarsE Registered Member #153 Joined: Sun Feb 12 2006, 03:44PM
I have built a ETG and got some good results using a 28,8Kj (36,5Kj if charged to their surge rating)
http://www.vimeo.com/751433
Gunner
Sat Jun 21 2008, 11:06AM
Lomy: What is your capbank specs?
LarsE: Ive seen ur etg in spudfiles and its REALLY powerful!:P
Gunner
Sat Jul 12 2008, 08:57AM
I am just wondering one thing, I explode a thin aluminum wire with 150J and the blast is pretty massive...but I tried to shoot projectile with it but projectile didn`t go even trough paper:p
