  • Guests: 65
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
Putting in a First Order for Parts
Firefox
Wed Jun 18 2008, 01:08AM Print
Firefox Registered Member #1389 Joined: Thu Mar 13 2008, 12:50AM
Well, after a few months of scavenging for parts, I've finally decided to actually order a small collection of parts so I don't have to scavenge as much for parts that I may need regularly. A large reel of 1N4007's is already on my list, and I am looking at ordering 100 or so BD139/140s that seem to be common in push-pull amps. The IRFP250 and 450 seem common, and I may order a few of those as well. I am also looking for an LCR meter and a high quality VI multimeter.
I am definitely going to order an assortment of resistors and caps, but I am unsure as to what to order since there are so many different values and types to choose from. Any pointers would be much appreciated.
Now I am wondering what parts you all have found that it is nice to have on hand for those pick up projects. Is there anything that I seem to be missing from pieces that seem to find their way into many moderately difficult projects? Thanks ahead of time.
Shaun
Wed Jun 18 2008, 01:16AM
For small capacitors and resistors, I bought the assortments at radioshack. That the only use i see in that store parts-wise.
Also, dont' forget to find a nice place to organize all the stuff. I have one of those little cabinets with like 25 plastic drawers, so I can just label them diodes, resistors, transistors, capacitors, etc.
ea6b607
Wed Jun 18 2008, 01:32AM
ea6b607 Registered Member #1320 Joined: Sat Feb 16 2008, 01:31AM
a nice set of breadboards and various solid stripped and bent wire segments if you don't already have some. Optoelectronics. a nice spectrum of resistors (it's a pain when you have to make a trip or order jsut because you need a couple resistors). perhaps some DIP 8 bit switches. All small things that come in handy. Ebay listings are always good for these things Link2
Wed Jun 18 2008, 11:50AM
Get a lot of 100nF low voltage foil caps, these are used for decoupling everywhere... Also the obligatory parts such as NE555 or TL494, you might as well get a KA/SG3525 which is similar to TL494 and has better output stage.
If you don't have one already, get an isolated low power variable PSU (with something 3-24V 0.3A or so, isolation comes in handy when operating circuits that are directly connected to mains) for powering all kinds of things - control circuits, GDT drivers etc., or you can build one yourself.
Also get a set of voltage stabilisators, IC sockets, perfboards or a breadboard too.
These are just things from my head right now...
Marko
Wed Jun 18 2008, 12:36PM
Firefox wrote ...
Why in world would you need 100 BD139 and 140? suprised
If you are going to order power devices, I'd rather look around something larger than IRFP450.
50N50 mosfets, hgtg20N60a4D IGBT's and similar are great choices as I see, if you are after solid state tesla coils. If you need faster mosfets those will usually be the smaller ones.
Marko
Wed Jun 18 2008, 01:00PM
Dr. Arc flash wrote ...
I daresay I'm to blame for their popularity. I don't use them for any reason other than that I got a pack of 50x BD139s and 50x '40s cheap once, and my cache of IRFP450s dominates my preferred choice of mosfet. shades Do like Marko says and look for better components. For simple push-pull amps find transistors with high gain and speed. BD1XX's are for audio amps, and have rather low gain. (Not to say they don't well though!) Hell, they might even be more expensive than more able transistors, I've never checked.
Get some operational amplifiers too, they're useful to have and can do anything. Make sure they have a push-pull output stage, otherwise they can't source current.
quicksilver
Wed Jun 18 2008, 01:25PM
When I ordered resistors I ordered them in 2w and even a few higher. The cost level for what spectrum I wanted was reasonable as the fill-in small scale stuff could be bought at Radio shack for a dollar or two.
I also made sure to order non-polarized caps. The polarized stuff I had was almost able to fill a grocery bag from TV's & monitors. But non-polarized stuff especially in HV or at large capasitence was tough to get without placing an order.
flannelhead
Wed Jun 18 2008, 02:28PM
What about also some UCC37321/22? These might be useful if you are into building SSTCs. And hey, it would be also good to buy some good ferrite toroids for GDTs; you never know about those you pull from a dead whatever device.
