  • Guests: 19
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
What Are Some of the Highest /Most Powerful HV Parts?
quicksilver
Tue Jun 17 2008, 06:59PM Print
Wiki describes the highest rated silicon switching Transistor @ 1Kv ( I don't know what they meant as per "rating" but if you look at the "disadvantages" of silicon-based transistors they claim 1Kv as a limitation....?) ... I was wondering what are some of the highest HV parts currently available?
Has any investigated the "Guinness Book of World's Records" rating of (single unit) Transistors, Capacitors & other passive components? With passive discrete parts that would raise some problems with resistors, I suppose wink Is there currently a standing strength/size recorded for a single CPU (not multiple core)? What are some of the highest rated parts available?
Wolfram
Tue Jun 17 2008, 07:18PM
I have seen datasheets for 6.5kV (IIRC) IGBTs for use in trains, but I don't know if they are multiple units in series internally, but I think they aren't.
When it comes to capacitors, I don' know of anyone making higher voltage caps than General Atomics, they have some caps rated for higher than 2MV here: Link2
Anders M.
Tue Jun 17 2008, 09:25PM
I believe I saw a datasheet for a 25 or 35kV transistor somewhere... or they were SCR's?
KresoLiubov
Wed Jun 18 2008, 04:25AM
KresoLiubov Registered Member #1153 Joined: Mon Dec 03 2007, 07:27PM
Dr. Kilovolt wrote ...
I wonder howmuch they cost
Mates
Wed Jun 18 2008, 06:00AM
I think the most powerfull switching devices (IGBT and thyristors) are used in HVDC power line systems. Something like this nice piece of silicon here... wink
A 2000 A 250 kV thyristor valve at the Manitoba Hydro Henday converter station, April 2001
Bipoleii Valve
rp181
Wed Jun 18 2008, 01:33PM
they have high voltage SCR's, diodes,and IGBT's, as well as hgih power, at 2kV, they have a SCR with 6000A continues!
ABB has the larges SCR ive ever seen, something like 100KA surge current, its 6 inches in diamiter!
Dr. SSTC
Fri Jun 27 2008, 05:45AM
Dr. SSTC Registered Member #1407 Joined: Fri Mar 21 2008, 07:09AM
i heard that panaonic made mosfets rated at 10 kv not sure of power rating
Fri Jun 27 2008, 08:44PM
Almost all high voltage switching devices are comprised of many "smaller, lower voltage" junctions in series. its just a matter of packaging the dies properly.
Dr. SSTC
Fri Jun 27 2008, 11:45PM
would it be posible to make transisters in series by connecting the emitter to colecter and bases in parralel, if it could what would the o0ther effcts be
Sat Jun 28 2008, 12:50AM
jovica93 wrote ...
Well you can hook two transistors together in a darlington arrangement.
About half way down it explains the darlington transistor and has a circuit diagram. Basically it will just increase the gain by hfe1xhfe2, So it will require a very small signal for it to turn on.
