  • Guests: 69
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
PS3 hackage?
Sun Jun 15 2008, 07:04PM Print
Hi all.
I just purchased a partially working (Bluray laser is low emission) PS3 for £120.
I did read somewhere that it is possible to use its Cell processor to do calculations that would make a quad core PC CPU look like a doorstop.
Has anyone else tried this? BTW yes the old Blu-ray module is getting used for various projects, as soon as the new one is here and installed.
Regards, -A
reign
Mon Jun 16 2008, 12:17AM
reign Registered Member #260 Joined: Sun Feb 26 2006, 09:51PM
I know you can install Linux on them pretty easily. From there, the possibilities are virtually endless. A quick google search should come up with some pretty useful information. I would find the PS3 Linux site for you were I not on my iPhone.
Bjørn
Mon Jun 16 2008, 12:57AM
The speed difference is not always significant, it all depends on the algorithm and on the skill of the person that wrote the code.
If we look at it realistically we got 6 cell cores at 3.2 GHz, each doing 4 floating point operations every cycle. Compared to 4 cores on a PC doing exactly the same thing. On real work like FFT there are plenty of cases where a dual core PC CPU beats the PS3 cell. And there are cases where the Cell is 3 times faster.
Carbon_Rod
Mon Jun 16 2008, 02:26AM
RH or Ubuntu (PPC) can be loaded via the loader (dual boot.)
For RH there is the cell processor toolbox from IBM.
Additionally, there are numerous frameworks like "bullet" (sourceforge/google) to support physics simulations.
See Blender 3D for Linux (includes bullet) ;)
ea6b607
Tue Jun 17 2008, 11:11PM
ea6b607 Registered Member #1320 Joined: Sat Feb 16 2008, 01:31AM
Bjørn Bæverfjord wrote ...
there are actually 10 cores. 1 is locked in manufacturing to reduce the amount of boards that must be discarded and one is locked to the ps3 OS. Linux has use of 8 off SPU's each at 3.2ghz. The thing that makes it such a processing power house is that the $400 system is able to preform as well as a couple grand PC at raw processing power. The best distro I've had is the PS3 version of Yellow Dog because it supports all of the hardware perifials (wifi, blutooth, and flash card slots) and it gives access to using the RSX GPU as well.
Hon1nbo
Tue Jun 17 2008, 11:15PM
[quote]
[/quote1213744406]
but the main thing is, since none of the programs for computers (with small exceptions) are made to run using more than two cores (four becoming more common), will there be a gain in performance at all due to the fact that using the extra cores requires new code (at least from my experience... but I doubt things have changed for attempting to use eight cores)
Bjørn
Wed Jun 18 2008, 12:17AM
There are 8 SPE (Synergistic Processor Elements) cores in the PS3, 6 of which is free to use. Then there is a PowerPC core and some other stuff but ony 6 cores are free for symmetrical parallel processing.
The peak performance of one SPE core is the same as for one PC CPU core, that is 8 floating point operations every clock cycle. So at peak performance the PS3 will win by 6 to 4. On real code the peak performance will go out the window and the winner will depend on the algorithm and the people writing the code.
So a modern PC is never going to be a complete doorstop compared to a PS3 unless it is set up to be by marketing people.
