  • Guests: 24
Ivan Kalafatic (17)
10/07 Pyromaniac (34)
10/07 Wavetuner (76)
10/07 jeffomatic (75)
Force meter/detector (using a ferrit torroid)
Madgyver
Sun Jun 15 2008, 06:46PM Print
Hi,
for some days I am trying to find a schematic for a force meter that uses a toroidal ferrit core. If a force is apllied to the core, it's characteristics change slightly (I can't remember anymore details).
I have seriuosly been loking for some days and can't find one, although I have found one (or it?) some years ago. This might be due to the lack of keywords to search for.
I hope some people here know what I am looking for and point me into the right direction with some key words (the main principle, or the name of such a device).
Thx
Carbon_Rod
Mon Jun 16 2008, 02:32AM
Not quite sure what you mean, but raw 3-axis magnometer sensors are $5 each.
Madgyver
Fri Jun 20 2008, 08:03AM
No, I don't want to measure the magnetic field. I want a force/pressure sensor.
I once saw a circuit that used a toroid ferrit core as the sensor element. But I am unable to find it again. Maybe one of you know a better solution.
Carbon_Rod
Fri Jun 20 2008, 09:42AM
strain gauge bonded to a metal block, simple ballistic pendulum, or a memsense.com unit.
Depends on the application.
Madgyver
Fri Jun 20 2008, 12:15PM
Well its for a actuator system to be used in a robot so pendulum is not a real option. Strain gauge has been tried but it's to difficult to make it work for normal forces. The memsense.com units look good but my budget is to small to afford a few dozens. But thx anyway.
Hon1nbo
Fri Jun 20 2008, 03:38PM
here is what you should do (I built one once, but I didn't build it well)... you have the wire wrapped doughnut core that has a suspended plunger with a magnet at the bottom of it, and above the centerline of the core, and there is a fixed, repelling magnet underneath the core and pushing up the plunger (it is how it returns to place and how the unit is calibrated, as the maximum force that can be applied which causes the two magnets to touch is the maximum capability of the meter)
