  • Guests: 72
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
SCR optoisolator flash
Hon1nbo
Sat Jun 14 2008, 12:30AM Print
hi, I have a NTE3046 SCR optoisolator, and I need to trigger a flash from an arduino's command (5v)... problem is, I don't know how to wire a photoSCR, as I don't know what to do with the gate (I assume everything else is the same)... the flash is between 200 and 300V
Sat Jun 14 2008, 03:29PM
I would assume you simply apply voltage to the gate through a resistor as usual, and use the optoisolator to trigger it. Some tests on a breadboard should indicate how it works.
Hon1nbo
Sat Jun 14 2008, 04:05PM
the SCR IS the optoisolator... they are in one package... here is the data sheet: here
Myke
Sat Jun 14 2008, 07:12PM
I guess the SCR is triggered by the LED but also you can manually trigger it with the gate.
Also remove the %20 (is a space) from the URL so it works
Hon1nbo
Sat Jun 14 2008, 07:17PM
lol, you accidentally put it where the "here" went and left the "insert hyper link here" text
anyways, I figured but when I try to use it, it doesn't seem to function (maybe the leakage is too high?)
when I press the button to turn on the LED (which does) the flash does not go off, but if I hold the LED on the manual trigger on the flash does not work (and it seems that the charging circuit is running non-stop) BUT when I release the LED button, the flash does not go off, but the manual button works now and if left undisturbed the charge goes down to zero on the flash (not normal with this flash)... [i]
Hon1nbo
Sat Jun 21 2008, 07:49PM
I decided to just to buy a regular optoisolator and use an external SCR... I was hoping to avoid that due to voltage spikes, but no big deal since I found some cheap ones locally...
