  • Guests: 43
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
Simple 800 volt capacitor charger.
Thu Jun 12 2008, 01:22AM Print
I am making a capacitor discharge thing... I need a simple way to charge from a battery. I have already started on a charger out of a psu ferrite. I have 10 primary and 6 feedback. I want to use the simpl single transistor feedback driver. The question is how many primary turns? Oh yea,the battery is 12 volts.
rp181
Thu Jun 12 2008, 02:38AM
If you want 800 volts with 10 primary turns, i think you will need about 670 turns, or a ratio of 1:67.
Thu Jun 12 2008, 12:16PM
I would use 5 primary and 3 feedback. I would also experiment with the "improved" driver.
Remember that the primary peaks a few times the supply voltage so you'll need less sec. turns, for the numbers I gave it should be enough to go with ~150 turns on the sec. (and get the polarity right of course)
