  • Guests: 17
Avalanche (42)
10/02 Carl A. Willis (45)
10/03 TwirlyWhirly555 (33)
10/04 Michael W. (36)
Building a CW
ea6b607
Wed Jun 11 2008, 05:19AM Print
ea6b607 Registered Member #1320 Joined: Sat Feb 16 2008, 01:31AM
Well I've never really much gotten into the true HV stuff past what I get out of my flyback, so I thought this would be a nice introduction to me. I have a few questions though. Well a lot of questions, not much looking to waste too much money or kill myself in the process. My plan is to run my MOT at high frequency to run a 5 stage CW (about 20kv output?) then I will use this to charge a Marx generator with as many stages as I see feasible.
1) can you use a CW to charge the capacitors in a Marx generator?
2) any good references for making a simple high frequency generator?
3) will a flyback transformer work?
4) do i need capacitors rated for the full output of the CW for all the stages. Also for this relatively low voltage what would be a decent frequency and a decent capacitance?
Sorry for so many questions, but this is a new area for me.
Berni
Wed Jun 11 2008, 05:54AM
Berni Registered Member #1132 Joined: Mon Nov 19 2007, 06:15PM
How do you expect a 50/60Hz microvave trasnformer to run at high freqency?
Why dont you just power it with your flyback if its not rectefied.
ea6b607
Wed Jun 11 2008, 06:44AM
That makes sense. Sorry if I say anything stupid btw. Wouldn't I need fairly high capacitance then with low frequency?
Lakeowner
Wed Jun 11 2008, 08:58AM
Lakeowner Registered Member #1370 Joined: Mon Mar 03 2008, 09:01AM
Yes, you will need bigger caps with lower frequencies.
Firefox
Wed Jun 11 2008, 10:59PM
Firefox Registered Member #1389 Joined: Thu Mar 13 2008, 12:50AM
I built an 18 stage CW with 400V 22 nF caps and 400V diodes, powered by an unrectified photoflash board. It worked just fine for charging a 22nF PET rolled cap, and a 4 stage Marx built from these caps.
ea6b607
Thu Jun 12 2008, 04:15AM
I stumbled across this on ebay Link2 it appears to be a several stage marx generator, but how on earth is it so small? I'm considering purchasing one to charge caps ina second larger marx generator think it would work?
teravolt
Thu Jun 12 2008, 04:21AM
mot transformers will not run more than 400hz because of the iron core. higher frequencies reqire ferite cores. I have used CW's to charge a marx.
quicksilver
Thu Jun 12 2008, 02:40PM
ea6b607 wrote ...
I am not sure but I believe they are hand wound coil and step-up , potted units made in Asia for the "stun-gun" market. Note the "6vdc to 100k" remark? I couldn't get a side view but I think I recognize this little item. They do put out a nice spark. But I'm skeptical about their longevity. They have a ferrite rod coil (that's the tough part to design & build) and a 4 stage crowded into a PVC potted with epoxy. I could be wrong; but it looks familiar.
