  • Guests: 44
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
molex connector question
teslacoolguy
Mon Jun 09 2008, 03:48AM Print
I was wonderng if any of you know what kind of molex connectr this is?
1212983195 1107 FT0 Dscn2831
I have been searching for almost 2 hours and i cant find out what kind it is because i need a male connector to match it.
cjk2
Mon Jun 09 2008, 05:33AM
Try digikey.com, they usually have a good selection of strange connectors. Is the pin spacing .1" ?
Firefox
Mon Jun 09 2008, 06:56PM
Firefox Registered Member #1389 Joined: Thu Mar 13 2008, 12:50AM
It is an extremely old six pin main power connector. Before 20 pin main bus supplies, one or two of these were used for power instead. Even in an old Dell XPS600T that I used to use before I got this one half a year ago, the 20 pin was augmented by one of these six pin connectors. I believe it is called an AT PSU plug.
The pin out is (thanks to Uzzor's site):
1- Power Good, +5 VDC.
2- +5 VDC
3- +12 VDC
4- -12 VDC
5/6- Ground
Hazmatt_(The Underdog)
Mon Jun 09 2008, 07:37PM
It is 0.100" spaced square pins. These are by AMP or WALDOM, MOLEX, its all pretty much the same company. I use these a lot in fact, its one of my standards for PCB interconnects for high current. A good electronic store will have packages of these Molex connectors hanging by hooks on a shelf.
You may be able to find some extra long square pins, put those in a Molex plug and use that as a shroud. These ones don't ordinarily have a connector shroud that I've seen, that's why I say that, I think they're usually moulded on.
Anyway, they're not rare or anything, but they aren't polarized either (if its just a bunch of pins sticking out), so you have to be careful how you hook them up.
teslacoolguy
Mon Jun 09 2008, 09:17PM
does radioshack have it?
Tue Jun 10 2008, 06:43AM
Unfortunately RS has reduced their stock to the point where if you're not sure they have it, you shouldn't bother going because they probably won't have it.
You can get them from any of the big guys like Mouser, Digikey, Newark, with a credit card order or phone order or whatnot.
But if you're in dire need of the parts you can put a post in the wanted thread for some of them. OR, If I can find some free time I may be able to cobble something together and send it out, but bare in mind that it may take me some time to get it done.
aonomus
Tue Jun 10 2008, 06:58AM
It looks pretty much like a 0.1" spaced molex, you could just order the male 6 pin connector then hack off the bit of plastic that polarizes the connector. Just be careful not to plug it in the wrong way...
