  • Guests: 70
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
H-bridge heat sink question.
Ken M.
Fri Jun 06 2008, 11:54PM Print
I am at a slight delema with an H-bridge circuit, I wanna use a AMd factory AM2 heatsink and mounting bracket for a H-bridge system. Now sure most of you would say sure this could easily be done with multiple heatsinks, or you might say I don't see an issue here. Well, the thing is, is that the H-bridge Is for a DRSSTc that is going to run at 24-170v DC, I also would like to keep it looking uniform, problem is I can't seem to find any more Identical heatsinks to the one I have, short of buying new Mother boards and AMD cpu's just to get the heatsink and mounting hardware. Also the circuit boards I want to use are roughly the exact dimensions as the AMD Heatsink. Also I understand that most people are starting to move towards the 1 heatsink per IGBT and presure mounted rather then being mounted with a screw principle. The question I ask is could all 4 IGBTs use the same heatsink for heat dissapation or do I need to find a slightly different aproach?
Marko
Sat Jun 07 2008, 12:30AM
Well, it all depends on power level of your coil. DRSSTC's can produce rather large sparks with just few hundred watts of input power, for which sil pads and single CPU heatsink may just be enough, and you could make everything very compact.
And still, how you mean you can't buy couple of identical heatsinks over there? They should be available in any PC shop. Very cheap too, they are <$10 a piece here!
Marko
Ken M.
Sat Jun 07 2008, 01:27AM
i tried Mwave.com, Newegg, tigerdirect, and ebay and non had the exact same package, plus the only reason I had all the mounting hardware for this heatink is cuz my pc has a performance heatsink installed with its own mounting hardware over the defeat hardware that came on the mobo. So to find the heatink and its appropriate hardware would require a bit of work.
Marko
Sat Jun 07 2008, 12:15PM
What power level do you intend again? It may just not make sense to use more than one heatsink for a low power coil. You haven't stated anything about your coil, so how you expect us to know if one heatsink is going to be enough or not? confused
I'm absolutely sure you have a swarm of PC shops over there considering there is couple just in my town (in a relatively undeveloped country).
I mean, real stores, not the internet ones! Although most of them here have everything on their web sites too.
Ask them for cheapest heatsinks available. The CPU heatsinks are actually the only ones I can get at fair price here!
Alternatively, you could ask this guy
To cut it in four for you. No fans but should be rather cheap for you considering you're in US.
Marko
Ken M.
Sat Jun 07 2008, 01:03PM
Most of the info regarding the Coil is in this topic Link2
The coil is based on Wards .5 DRSSTC ExceptI don't wanna go any higher then 170VDCin so no Voltage multiplier it would just be a bridge rectifier and some storage caps.
Power I'm looking for a max of 200W.
As for the PC shops theres 1 in town, then theres radio shack and walmart in the next town over and they only sell premade pcs from name brand companies.
BTW I thought I'd post a pic of the Heatsink.
1212843755 618 FT46801 Top Heatsink
1212843755 618 FT46801 Side Veiw Heatsink
Marko
Sat Jun 07 2008, 01:15PM
Hm, I got pictures of something else when searching for 'AM2 heatsink', didn't know yours has heatpipes and all the mess...
In any case, if you aren't pity about drilling that heatsink, it is a huge overkill for that power level, it will be more than fine.
You would have lots of margin to soup up your coil later too.
I don't see why not to use doubler BTW, decreasing the peak current for same power level is always good.
Marko
