  • Guests: 29
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
finding the inductance
Avi
Tue Jun 03 2008, 07:59AM Print
method 1, measure physical size:
L(uH)=((turns*radius in inches)^2)/((9*radius in inches)+(10*height in inches))
L(uH)=((18.75*1.75)^2)/((9*1.75) +(10*2.15))=28.9uH
method 2, connect it in series with a pot to a signal generator and scope the voltage across both and adjust untill equal. Then measure the pot to find impedance:
measured: 28 ohms at 80Khz (4 cycles in 10 divisions at 5uS/div)
Xl=2*PI*F*L
L(H)=Xl/f/PI/2
L(H)=28/80000/ PI/2=55.7uH
difference of 50%
so which one is it?
or is it none?
should i do some other sort of test?
Hazmatt_(The Underdog)
Tue Jun 03 2008, 08:43AM
I think you should check your size formula because I think you may have a centimeters/inches error. I could be wrong about that, but when I do the size calculations they're usually pretty close, like 90%.
Your measured is almost guaranteed to be right with the provision that the probe isn't affecting your measurements too much. I'd suggest go back and measure at 1kHz so capacitive effects don't play a large role, and then see how it deviates from the 55.7uH measurement.
Thought comes to mind, this is a single layer solenoid right? Because the formula is different for multiple layer solenoids.
Avi
Tue Jun 03 2008, 08:56AM
i used a ruler with inches on it..... though i took the 3.5 inch diameter and halved it (1.75) for the radius measurment
actually i just use a bit of wire then proper oscilloscope probe, but i did that on both channels.
at 1Khz the inductor is going to have some ridiculously low impedance that i would not trust the accuracy of my dmm.
yes, this is a single layered cylindrical coil, same top and bottom diameter too.
Dago
Tue Jun 03 2008, 11:31AM
Dago Registered Member #538 Joined: Sun Feb 18 2007, 08:33PM
I'd say say your frequency measurement might be off aswell, 4 cycles is a bit low for determining the frequency, you then have an accuracy of 20% (assuming your counting whole cycles). Looking at more cycles will give you more accuracy.
Avi
Tue Jun 03 2008, 11:47AM
well, yeh, but i did line it up against a flat line on the other channel so there was exactly 4 lots of 360 degrees on the screen. ok i will count it again with a different time/div
Dr. Slack
Tue Jun 03 2008, 12:52PM
The most difficult test to get wrong (I think that means what I meant) is to resonate the coil with a known capacitor and then find the frequency. You can use them in parallel and measure the frequency of highest voltage rise by feeding it and measuring it with a high impedance. Or you can have them in series and measure where their impedance is lowest, perhaps by putting them across the output of your signal generator and tuning the frequency for the lowest terminal voltage.
But it does need a known capacitor.
Avi
Tue Jun 03 2008, 04:32PM
i took another measurement at 90Khz (18 cycles at 20uS/div) and ended up with 23.3uH
weird....
Bored Chemist
Tue Jun 03 2008, 05:09PM
Great, now you know that you don't know the answer smile
Are you planning to use this as a TC or something where it will be used with a cap as a resonant circuit?
If so, do you have the cap you plan to use?
Measuring the true resonant frequency is more useful than knowing the inductance.
Anyway, I'd try again with a few different frequencies, preferably over a bigger range than 80-90KHz
Other things to worry about are distortion (does the 'scope trace look like a decent sine wave?) and loading; is the signal generator struggling to feed the load or is the scope loading it down?
With a measured impedance of just 28 ohms I think the former is more likely to be a problem than the latter.
Avi
Tue Jun 03 2008, 06:37PM
thread continued here due to slight change in topic
