  • Guests: 45
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Another resonant MOT topic...
Spedy
Sat May 31 2008, 06:19PM Print
Spedy Registered Member #964 Joined: Wed Aug 22 2007, 12:39AM
Ok. I searched through EVERYTHING, but I couldn't find any info on my questions.
1) Do the 2 caps need to be in parallel or series for resonance with one MOT? Do I need more than 2 MOCs? I only have 2..
2) Do I need more ballasting for 2 MOC resonance?
I have 2 MOTS, (1x 1100 watt, 1x 680 watt), and 2 MOCS (1x 74uF 1x 76uF)
Thanks!
Sat May 31 2008, 06:49PM
Spedy wrote ...
Thanks!
Hi, with 1 MOT, you want 2 parallel capacitors.
You might find that the arcs are not stable, then connect the other MOT as an inductor (shorted secondary, and primary in series with the primary of your powered MOT), use the smaller one as an inductor.
EDIT- like this:
1212260005 152 FT46310 Resonantmot
Myke
Sat May 31 2008, 07:47PM
They should be in parallel. More than 2 MOCs would be better because the more there are, the less current has to go through each one.
You could also connect 2 MOT primaries in series and also connect the secondaries in series. I think this brings both MOTs out of saturation.
Spedy
Sat May 31 2008, 09:05PM
Thanks. When I get more MOCs I'll be sure to add them.
Time to go assemble the thing...
Ok, parallel MOCs, shorted secondary MOT for ballast on primary circuit. Gotcha.
Dragon64
Sun Jun 01 2008, 01:21PM
Dragon64 Registered Member #1438 Joined: Sat Apr 12 2008, 12:57AM
One more question, is it possible to create Resonant with three MOC's in parallel?
And also, what would happen if connected three MOC's in series with a shorted MOT for ballast?
Sun Jun 01 2008, 01:38PM
hydraliskdragon wrote ...
Yes, it is possible to use up to four MOC's in parallel for one MOT but it will be smoking in seconds. It will go for maybe half a minute with three.
"And also, what would happen if connected three MOC's in series with a shorted MOT for ballast?"
Where would you connect them, across secondary or primary of the ballast MOT? If primary then probably nothing, if secondary you would make smaller arcs.
Dragon64
Sun Jun 01 2008, 02:39PM
Would these work then on 120V?
Sun Jun 01 2008, 04:40PM
The first one will work, you can also remove the ballast MOT for more power as with 3 caps the arcs are usually stable.
The second one will not work (you need at least 2 SERIES caps with 2 MOTs, then you can parallel more of these strings to get 4,6 etc. caps.)
With 2 MOTs the ballast one will ballast it too much, two parallel ballast MOTs would be needed.
Spedy
Mon Jun 02 2008, 12:03AM
Hmm, Another question:
How do you connect the "other" terminal for arc drawing? It seems like it would be really hard to solder to the core of the MOT..
Myke
Mon Jun 02 2008, 02:54AM
You can just use a screw or something to connect to the core. If you don't have a screw that fits, you can drill a hole into the metal plate and use a bolt or something.
