  • Guests: 52
thyristor?
Solidacid
Sat May 31 2008, 12:55PM Print
Solidacid Registered Member #1430 Joined: Sun Apr 06 2008, 11:12AM
hey all.
im working on a small coilgun and i need a trigger, i found This.
i was wondering, how can i calculate the maximum amount of uF at 300v i can switch with the thyristor.
also, how do i figure out the "amps" of a capacitor based on uF?
Bjørn
Sat May 31 2008, 04:20PM
Keep the datasheet in one hand and this in the other: Link2
Each capacitor is different so you need to read the datasheet for that too.
Solidacid
Sat May 31 2008, 07:50PM
this is just what i needed :D thank you!
now i just need to figure out the inductance(H) of my coil, any suggestions?
i read somewhere that you can calculate it with a sinewave generator but i don,t have acces to one
Sun Jun 01 2008, 11:17AM
Without a scope or LC meter you'll need to use math to estimate the inductance. Link2 Make sure you find one for multilayer coils.
Saz43
Wed Jun 18 2008, 06:05PM
Solidacid wrote ...
Fraggle
Thu Jun 19 2008, 02:55AM
Fraggle Registered Member #1526 Joined: Mon Jun 09 2008, 12:56AM
I find the mains to be a handy sinewave for measuring inductance.
Shaun
Thu Jun 19 2008, 04:00AM
Definitely use the site saz linked to, its very good. Don't forget to check out his RLC simulator as well, its number 3 on the Mark II menu. RLC sim will take your capacitor and coil specs and tell you peak amps, among other things.
Dr. SSTC
Sat Jul 26 2008, 08:59AM
Dr. SSTC Registered Member #1407 Joined: Fri Mar 21 2008, 07:09AM
that thysistor propably would work
