  • Guests: 23
Ben7 (29)
12/18 Skywarrior (52)
12/18 Dark Horse (54)
12/18 LD LANGER (38)
protecting from ringback and EM pulses
rp181
Sat May 31 2008, 12:04AM Print
So for my upcoming railgun project, I was wondering how powerfull of diodes i should get to protect the capacitors. The only way i see to do it is mesure the resistance and inductance of everything, which i have no way to mesure acruatly. I was planning on 5kJ at 450-500V. What surge current should i look for? im leaning toward 1000V diodes to be safe. What saftey factor should i leave?
There is also the problem of EM pulses, how can i shield from these? i want to record it.
ea6b607
Sat May 31 2008, 04:52PM
ea6b607 Registered Member #1320 Joined: Sat Feb 16 2008, 01:31AM
Low inductance in a railgun means you shouldn't need a protecting diode (I didn't and my cap bank still is fine) As for EMP, I didn't experience any problems with it and I had a microphone only about 12" away from the rails. If your doing this for a science fair I would strongly suggest something less lethal.
Backyard Skunkworks
Sat May 31 2008, 04:54PM
For EMP protection you'll need a Faraday cage, basically just grounded mesh screen enclosing everything. Also remember that the magnetic field falls off with the square of distance, so keeping everything several feet away is good.
Donno about the diode, depends on the resistance and inductance of the gun, which I have no idea of, seeing as I havn't built a railgun yet.
rp181
Sat May 31 2008, 07:33PM
This is mainly because i want to do it, science fair is an added bonus =). its not going to be done there.
For the faraday cage, how do i know how big to make the cells? Could i just wrap the equip in ALU foil and ground it?
Backyard Skunkworks
Sat May 31 2008, 08:15PM
Well yes, if you wrap the equipment like a freakin mummy! However I would be inclined to agree with ea6b607's statement that a faraday cage is not essential. Keeping all the equipment 4+ feet away should be good, but IF you really want to keep things 100% safe, just use Al foil and some type of mesh for windows.
rp181
Sun Jun 01 2008, 12:04AM
didn't want too post a new topic, if 2 fuses are in seris, will the rated voltage double?
ea6b607
Sun Jun 01 2008, 01:34AM
no, still can't handle more then the rating.
rp181
Sun Jun 01 2008, 01:00PM
so there is no way to increase voltage rating? i read that it lowers i2t fusing, what is this?
