  • Guests: 45
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
Arbitrary size steel pipe suppliers?
Liam
Fri May 30 2008, 08:10AM Print
Liam Registered Member #113 Joined: Fri Feb 10 2006, 01:40AM
It's good to be back at 4HV! It's good to be home from uni so I can work on more interesting projects smile
I've googled around for quite a bit and searched McMaster. They don't have 5/8" pipe with a 1/8" wall, for instance. I've come very close but can't find anything quite close enough. Any ideas on pipe suppliers? US-based is preferable but foreign is fine as well.
ea6b607
Fri May 30 2008, 07:16PM
ea6b607 Registered Member #1320 Joined: Sat Feb 16 2008, 01:31AM
onlinemetals.com has a fairly decent selection
here's what your looking for in aluminum Link2
Andyman
Sat May 31 2008, 05:58AM
I think he was referring to plastic pipe for coil forms.
ea6b607
Sat May 31 2008, 06:08AM
oh my bad. That makes more since. You'll have a better selection in polycarbonate although its a little more expensive. 8585K53 part number on McMaster-Carr
Liam
Sat May 31 2008, 05:29PM
Sorry, that was something I should have specified. I'm actually looking for steel. Thanks for the information thus far.
Sat May 31 2008, 06:53PM
Have you looked at 1/2" EMT conduit? It is 1/2" inside and Im pretty sure it has a 5/8" OD (Ive never measured it at work). Its not pressure rated or anything but it is moderately strong and pretty cheap.
Liam
Sun Jun 01 2008, 05:53PM
Unfortunately, I need something pressure rated (the wall needs to be rather exact). I'm sure there's such a tube out there - 3.25mm wall, 15.88mm diameter.
