  • Guests: 25
M.A.D. (32)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
Linear regulated power supply design
aonomus
Wed May 28 2008, 05:22PM Print
Well, I'm in the process of designing a small benchtop power supply because I can't afford a commercial one (and I want to learn how to build one anyways). Attached is my draft schematic pending a sanity check. It has a positive/negative variable output, and a fixed 5v output for TTL stuff...
Draft
I already salvaged a pretty nice centertapped 16-18V transformer that is pretty beefy out of a UPS however I'm not sure as to determine its max current rating on the secondary. It has a 10A circuit breaker on the primary 120VAC side, however I doubt I would want to push it to that point as the breaker is more likely there because there was a downstream outlet on the back of the UPS hooked into the input cord through the breaker. How can I safely determine the max rating across the secondary?
Either way, the other question I had was regarding current regulation, is there a more efficient way of regulating current than simply passing it through a rheostat? I saw a few transistor configurations looking around, but I'm wondering what is an efficient method to regulate current without having the possibility of the rheostat changing resistance as it heats up?
And one last [stupid] question: what category does Eagle file a symbol for a 120VAC plug under!? I've looked everywhere that would make sense and its driving me nuts.
Edit: Forgot to include (50v 2.2uF) smoothing caps on the outputs, those will be included in the final design, the 10uF caps are to smooth out any ripple from the pot.
Further edit: forgot to mention also, the 317/337's are not the ones to actually be used, I will find either 3A or 5A adjustable regulators from Digikey and heatsink them appropriately. I only used them as placeholders since they are convenient.
dingo27
Wed May 28 2008, 11:40PM
dingo27 Registered Member #890 Joined: Tue Jul 10 2007, 10:06PM
when i was doing my ps, i found some time later that ih had the 3A 5V (but it could give 20V but low A), and ine little thing - i was always able to get more current through 317 that factor 1,5A, the max value i was able to get was near 4A ( it was overheated but it was funny working... ) i never burned any lm317...
and i think that 5V for TTL is not bad , but sometimes i use 5,5 / 6V for TTL (once i was using 7, but it was nearly to collapse ), and if i were building that PS, i would give that larger DC filtering Cap (1000-2200uF and protective diode across LM317 circuit (or that you are going to use)
aonomus
Thu May 29 2008, 02:31AM
Ok so I revised with protective diodes on all the regulators, probably a good idea since I'd be using the 5V rail to power TTL stuff while I use the variable to power say, motors or other inductive loads that might have a fair bit of back-EMF
Draft2
Also this is the transformer I salvaged, very clean and already terminated with quick disconnects, but can anyone make sense of the transformer markings and as to how many VA the transformer is?
1212027738 1497 FT46077 Psu Xformer
Also I would not be surprised if the current regulation is non-linear and dependent on output voltage since at minimum voltage the regulator has got to send current somewhere. Either way there are some 5A or 3A TO220 packaged regulators that would work quite handily for the variable ones, only a few dollars from digikey.
Another note is, does anyone know a non-rheostat method of controlling current?
Thu May 29 2008, 02:47AM
Okay a few problems with your design.
1. You need some ceramic caps on the input / output of your 780x regulators. You need this for stability reasons, otherwise you may have some problems during load transients and get some oscillation. I typically use 0.1uF on input and output.
2. You need diodes across input to output on your 780x regulators. Because you have lots of output capacitance, you need to provide a discharge path from output to input, when you disconnect the input side from the supply (OFF). Otherwise, you'll damage the regulators.
GeordieBoy
Thu May 29 2008, 09:46AM
I'd also be concerned that you might exceed the maximum rail-to-rail supply voltage rating of that op-amp since it is connected across the un-regulated supply.
aonomus
Thu May 29 2008, 10:05PM
GeordieBoy wrote ...
Yea, the TL071 is listed for +/- 18v, the only problem is that a AC spike might exceed it enough. Could I tie it into the -5V supply, or does the input voltage need to be tied to the one it is regulating, thus using a pull-down resistor instead?
Edit: I went out and purchased the 7805, 7905, and the LM317/337s, I figure if I strap them onto a big enough heatsink, all should be good. I'm going to find or buy a old surplus P2/P3 slot2 heatsink since they're no longer in use.
aonomus
Sun Jun 01 2008, 07:49AM
Well it would seem that theres a difference between 8V centertapped (ie: 2x 8V) and 16V centertapped. My bad. So I'm faced with either making this a 0-12V and 5V PSU, positive only, or 0-8V and 5V +/- PSU. Do many people find themselves using the negative voltage often? If there isn't a huge use for the negative voltage I'd be better off making this a 12V power supply (since it was salvaged from a UPS powered by a 12V battery).
1212306504 1497 FT46077 Xformer Output
aonomus
Mon Jun 09 2008, 03:37AM
This might be a slight bit of a necro, but I managed to find a 60V centretapped transformer for the power supply. Since the -ve unregulated rail to ground will be 30V, the TL071 won't be able to sit on it directly. I won't be frying anything by just hooking the TL071 to the -5V rail right?
