  • Guests: 43
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
Induction heater as an induction launcher (now with control circuit discussion!)
1 2 3 4
Tue May 27 2008, 07:10PM Print
I've been playing with somewhat more powerful induction heater over the last few days, and when attempting to heat various work pieces I noticed I couldn't get a coin to sit still. The coin is 75% copper, 25% nickel, otherwise known as a Norwegian enkroning. It was perched atop a bolt, and when I tuned for resonance it would jump off. I've just made a Rube Goldberg machine! Video. This shows how much current there is circulating in the work piece!
Anyway now that I got your attention I can ask a quick question. What kind of coupling do I want in an LCLR induction heater? As high as possible? I'm using incredibly low coupling right now and I don't seem to be getting anywhere near the power transfer I expected. At the same time I've found large work pieces damp the work coil current so much that it hardly heats anymore, and with no load the current drawn from the inverter sky-rockets. So will higher coupling damp the resonance so much that it stops heating? Or can I increase the coupling, reduce the matching inductance, and never run it without a work piece anymore?
GeordieBoy
Thu May 29 2008, 10:02AM
Re The rotation of the workpiece. You ideally want high-coupling between the IH coil and the workpiece. If un-constrained a coil will rotate in such a way that it minimises it's cross-section that couples with the magnetic field lines. Essentially it will stand on edge and stay relatively cool because only a very thin cross-section cuts the field.
As you discovered the power transfer is highly dependant on the coupling factor and the damping that a particular workpiece creates (Q-factor) when inserted into the work coil.
It is unlikely you will find one combination of work-coil and impedance matching components that will allow you to heat a variety of different materials and sizes of workpiece satisfactorily without adjustment! That is why real induction heating setups almost always have the work coil made specifically for the job in hand, and there are hundreds of different coils. Even then they still allow a component in the matching network (such as the L part of L-match network) or a transformer tap to be changed to suit different loadings.
Current draw from the inverter increases when there is no workpiece present because the tank Q tends towards infinity and you must be tracking the resonant frequency. What you really want to do is sense the work-coil current and control the inverter frequency in such a way to keep the work-coil current constant. With this control in place, the work-coil current (and cap current) will not sky-rocket to dangerous levels if the workpiece is removed. Since Q factor increases as the workpiece is removed the actual power supplied by the inverter to maintain a specified work-coil current decreases. If you get the coupling and control right, you can expect the line-current draw to increase noticeably when you insert a workpiece into a previously empty coil.
-Richie,
Tonskulus
Thu May 29 2008, 01:18PM
Tonskulus Registered Member #1223 Joined: Thu Jan 10 2008, 04:32PM
Yes, i have noticed that too. Look at my induction heater video to see some induction launching happening:
http://www.youtube.com/watch?v=iDg4pXpS-Xk
Actually, it is possible to levitate some workpieces putting that piece beetween two workcoils. Bottom coil should be a bit larger than top coil.
Thu May 29 2008, 02:25PM
It makes sense now Richie, thanks. I've only been monitoring the current drawn from the inverter and forgot that the tank current behaves differently. It would take some fancy control circuit to do constant current control by frequency given how the LCLR responds, I'll have to see about that one. I just wonder how it would behave since once it passes to the wrong side of the frequency hump everything becomes inverted. As long you don't try regulating the current too high, and thus force the circuit to lower the frequency over to the capacitive region it should remain stable I think.
Tonskulus, I saw your video this morning actually. Are you using Kim's circuit?
Tonskulus
Thu May 29 2008, 02:49PM
Uzzors wrote ...
Yes, it is almost like kim's circuit but there are some different solutions anyway. Basic circuit is the same. It seems to be reliable so I don't see any point about making it more complex. My system has also system that keeps input current constant. Like 20Amps or so, what ever I want it to be. It is not active forward converter, it is just automatic L-match adjusting system (Ferrite core is moved by solenoid).
GeordieBoy
Thu May 29 2008, 02:55PM
Hi Uzzors,
You always want the inverter driving on the high side of the LCLR network's pole frequency (maxiumum power point.) This ensures ZVS of the switches under all load conditions. And ideally at very high power you would like the operating frequency optimised to be somewhere close to this resonant frequency so that the power devices don't have to interrupt too much current. In a rough "one size fits all" DIY design, this won't be the case though.
As it shows on my IH web page, power control can be achieved in many ways. Varying the drive frequency is just one method. (A controlled thyristor bridge to vary the DC bus voltage is another common technique.)
In the variable-frequency case you have two control loops: one that tracks the resonant frequency, and one that controls the power level. The strategy is basically as follows:
Start with a high drive frequency and sweep the drive frequency down until EITHER the requested work coil current is reached _OR_ the resonant frequency of the LCLR network is reached (maximum power point). If the resonant frequency is reached first, and the power throughput at this point is way too low, then the matching inductor or coupling needs to be changed to get more power throughput. Most commercial heaters will indicate this as a tap change required inside the heat station.
If you use a VCO, there are basically too things that can "increase" its running frequency. If the phase angle between tank voltage and inverter voltage is less than 90 degrees, or if the tank current (or tank voltage) is greater than requested. Whichever one of these criteria that dictates the highest operating frequency is the one that wins the battle and takes control of the VCO at that moment.
So for example, if there is no workpiece installed tank circuit Q is very high and the power control loop will push the operating frequency right up to keep the work-coil current under control. As a lossy workpiece is added, the Q-falls. The power control loop will request progressively lower frequencies in order to maintain the requested work-coil current as the Q decreases. Power sourced by the inverter will increase and become more in-phase as the resonant frequency of the LCLR network is approached. Eventually the resonant frequency of the LCLR network is reached by the VCO and the tank circuit voltage lags inverter output voltage by 90 degrees. Adding further load to the workcoil will cause the frequency tracking loop to take over. This will act to keep the VCO operating at the resonant frequency where maximum power is delivered as the properties of the workpiece alter the resonant frequency of the tank circuit. If we quickly remove a lossy workpiece from the workcoil, the power control loop will instantly take control again and the drive frequency will shoot up to stop the tank current going sky high due to excessive Q.
I hope this explanation helps.
-Richie,
Experimentonomen
Thu May 29 2008, 04:35PM
I had the idea of letting the tank current control a servo motor which would adjust the gap in the matching inductor.
But i never got that far cuz i wrecked the core i intended to use.
Thu May 29 2008, 07:18PM
Tonskulus wrote ...
Mechanical current control? suprised Have you posted your heater in the projects section yet, or did I miss it?
I've made a preliminary circuit which needs a sanity check. I expect there are flaws in the phase comparator section since I don't quite understand how it works. First the soft start which ensures the VCO starts at max freq. In the meantime the tank voltage rises and is stepped down and averaged, later compared to what the safe value is. Error is feed into the VCO. The phase comparator does what it does...
1212088571 95 FT46031 4046 Ih Advanced
GeordieBoy
Thu May 29 2008, 10:30PM
Uzzors, conceptually your schematic looks fine - It includes all the important elements. There are a few things that you might need to change though:
1. There should be a pull-down resistor at the VCO control voltage input pin after the point where the control signals are OR'ed together with the signal diodes, (pin 9.)
2. You will also need some kind of pull-down, and possibly and amplifier or clamp on the tank-voltage sense line feeding into the phase comparator (pin 14.)
3. The other input to the phase comparator should come from the inverter output voltage. Without looking at the PLL datasheet i'd guess that it's currently coming from the VCO output instead.
4. You might need some compensation components around the error amplifier that senses and controls peak tank circuit voltage. At the moment the loop gain and bandwidth will be very high so it may oscillate wildly instead of smoothly and quickly settling to the power level you request.
5. The analogue "soft-start" circuit you show might need a diode across the resistor to quickly reset it if you turn the power off and back on again. If you wind up supply voltage slowly with a variac (or have soft-start on the DC bus, you can probably do away with this part, and the over-current detect should be fast enough to catch it anyway.)
6. You might need to buffer the output from the PLL loop-filter to prevent it's response being messed up by the diodes and pull-down resistor that follow the loop filter.
7. You will have to choose the resistors on pins 11 and 12 so the VCO runs over a suitable range. You don't want it to start at a frequency that is too high and damages the power electronics, due to improper gate-drive etc.
At this point I should also say that Steve C has reported good success with a similar (but possibly simpler) PLL based controller for induction heating. However his design is very close (if not identical?) to what he used to control a DRSSTC. In a similar way to current limiting in a DRSSTC it achieves control over induction heating current by turning off the drive for a few cycles when the current gets too high. This may be "closer to home" for those familar with DRSSTC operation and apparently worked well.
-Richie,
Fri May 30 2008, 09:58AM
Yes, I just used one of my Mk2 DRSSTC drivers without any mods. The current limiter provided a kind of rough power control, and a variac did the rest.
The only drawback I found was that the PLL sometimes wouldn't lock by itself when DC bus voltage was applied. It needed a poke at the tuning pot to nudge it into lock. I think this was a Catch-22 situation: if the frequency started far enough away from resonance, it couldn't develop enough tank current to get any feedback signal. I've seen a sweep oscillator used in other applications to break vicious circles like these. It basically flaps the VCO frequency around until it locks.
I also used the series resonant setup, just because I like it more than the LCLR. I don't know how my driver would behave with an LCLR.
Connecting the phase comparator straight to the VCO output is a cheap and nasty shortcut, and I'm to blame for promoting it, since I've always done it in every PLL circuit I've published. The only advantage of it is to avoid the hassle of high-speed isolation circuitry for sensing the inverter output voltage.
I tried making a "bucking coil" like Tonskulus described, and was just able to levitate some pieces of aluminium. I had the current limiter disabled and the variac turned right up to 270V, and it was all going fine until the levitating workpiece melted, went unstable and fell out of the coil. You can probably guess what happened next frown
