  • Guests: 159
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
How to create a suitable reference voltage for a comparator?
Dago
Fri May 23 2008, 02:31PM Print
Dago Registered Member #538 Joined: Sun Feb 18 2007, 08:33PM
I'm making a DDS-based function generator and I'd need to make an output stage for the DDS-chip (AD9833) which outputs around 200mV p-p signal. The frequency range the DDS-board generates is from about 150Hz to 8MHz
I'd want two outputs, one for sine and one for 50% duty square wave. I know the DDS-chip can generate square wave by itself but I cant really use that feature due to how the LC-filter after the DDS-chip is built plus I dont have a programmer to program the pic with. So I need to generate the square wave from the sine.
The sinewave is pretty easily amplified with a noninverting opamp amplifier (I was looking at EL2044 as the opamp) and AC-coupled to yield a nice 5V p-p signal.
The real problem is how to make the square wave? The problem lies in that the signal from the DDS-chip varies a bit with frequency, the amplitude gets smaller in both of the extreme ends of the frequency range. How can I create a fairly stable 50% duty square wave from this signal?
Using a comparator for doing it is clear but how do I make the comparator to trigger at halfway of the sinewave cycles so it would consistently keep 50% duty even when the input signal varies a bit in amplitude? I'd need to somehow change the comparator reference voltage so it would change according to input signal amplitude but I cant think of a good and easy way to do this. Any suggestions?
Fri May 23 2008, 03:41PM
Shouldn't it be possible to AC couple the into the sine wave so that it is centered around 0v, and then set the comparator to trigger at 0v?
GeordieBoy
Fri May 23 2008, 05:16PM
You might want to consider using the AD9834 DDS as this has an internal self-biasing comparator if I remember correctly and is also a more modern part.
As you correctly said, the squarewave should be generated using a comparator acting on the analogue sinewave _AFTER_ the lowpass filter. Any digital squarewave generated directly by the DDS has period jitter which becomes more significant at high frequencies, and you certainly don't want to put the squarewave through the lowpass filter!
If your eliptic reconstruction filter is designed properly then the period jitter on a squarewave generated the proper way with a fast comparator should be very low up to F_clock / 3.
-Richie,
Fri May 23 2008, 09:38PM
I'd go one step further and recommend the AD9850 smile Even if you don't use it, you can read the AD9850 datasheet to see how its built-in comparator works.
I built a 0-40MHz generator based on this chip and it worked well.
Dago
Sat May 24 2008, 06:35PM
I also thought about biasing the sinewave around 0v, then if the sinewave amplitude changes the sinewave should still be in the same position in relation to ground and you could make the comparator trigger at 0v. Another idea was to generate the reference voltage with a RC-filter but I dont think this can be made to work on such a wide frequency range.
I cant really change the DDS-part because its made from a kit, the board is meant as a VFO for a radioreceiver/transmitter (check out Link2 )
Edit: Fixed bad link.
Dago
Thu May 29 2008, 01:21PM
I found this: Link2 but I cant really understand how it works. Though I'm pretty sure the 4069 is a tad too slow for 8MHz?
