  • Guests: 35
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
PC Oscilloscopes on Ebay
jpsmith123
Tue May 20 2008, 12:00AM Print
I'm wondering, does anyone have one of the Chinese-made USB PC scopes selling on ebay, and if so, how do you like it?
This is the kind I'm referring to:
Experimentonomen
Tue May 20 2008, 01:32PM
I have one of those, its nothing great, 8bit is quite grainy, a real oscilloscope is much better.
Tue May 20 2008, 05:45PM
lol!!!!! i've seen a better 'scope using a PIC microcontroller (12F675) running at 27 MHz, driving a small CRT from a camcorder... :)
8 bit is really sucky, but OK for audio work. I suppose it could be useful to compare two signals, but the real grunt work requires a DSO and/or at least 500MHz 'scope.
Tue May 20 2008, 07:04PM
I would say quite the contrary, 8 bits is more than you would be able to discern on a normal 4" CRT scope (in order to get 8 bits out of a 4" analog scope you would need to be able to measure to about .015").
Also 150MS/s should be plenty fast for most of the work we do, as long as you don't try to get into coils running at 10+MHz...
but you do need to drag a laptop with it,
aonomus
Fri May 23 2008, 04:55AM
On one hand you have the ability to capture events on PC scopes, even a free version using the soundcards ADC, and for certain tasks capture is invaluable or even required, but even my ghetto 20MHz Philips scope works wonders compared to the physical interface of a computer. The knobs are a great asset compared to dragging virtual knobs using a mouse, not to mention that there is the ever so slight risk that cheap models might not have proper isolation, thus frying your laptop, costing more than a used scope.
Another downside to real scopes vs PC scopes (or digital) is that at very long time divs, the draw time (on some tube based scopes) can be so long that you can't get a good impression of the waveform, whereas capturing scopes can display the waveform in its entirety.
jpsmith123
Sat May 24 2008, 03:58PM
Hello HFsstc-freak,
I'm wondering, is the DSO-2150 "isolated" from the PC?
Experimentonomen
Sat May 24 2008, 06:49PM
No its not, the probe grounds are connected to usb ground.
jpsmith123
Sat Jun 14 2008, 02:01PM
Well I decided I'm going to get one of these usb scopes. I would've preferred a "real" scope, but to get the equivalent bandwidth would cost almost three times as much money...which I just don't have to spend.
I almost went with the Owon 25 Mhz stand-alone, i.e., "real" scope, until I realized that it doesn't have a TFT LCD display.
I wonder if there's any affordable way to isolate a usb scope from a computer?
Ken M.
Sat Jun 14 2008, 02:12PM
Actually Jp
and also in the owners manual,
"8"TFT LCD (liquid Crystal Display)"
"640 (horizontal) x 480 (vertical) pixels"
"260000 Colors"
.....The owon scopes have a TFT screen.
Sorry for multiple links..just wanted to provide more then 1 source that says its a tft lcd scren.
Hon1nbo
Sat Jun 14 2008, 02:16PM
I built mine from a CRT TV, so far I never really made a usable one (60Hz) as I plan to buy a unit...
