  • Guests: 52
Tube Rectifiers:6X4
EDY19
Fri Mar 17 2006, 02:10AM Print
I've decided to make a tube preamplifier, probably using 2 smaller tubes such as the 12AX7/12AT7 etc. and i have a rectifier tube, the 6X4- Will this tube be able to handle the current that will be required to run these other two tubes? I know the rectifier tube is rated at .6A , but I have no idea what the other tubes use.
Hazmatt_(The Underdog)
Fri Mar 17 2006, 03:59AM
You're looking at 5mA per plate structure. No problem.
It's .6A heater current. 45mA Rectifier plate structure, so 90mA in parallel. It's about 40W max handling. You could have a nice 6V6 push-pull amp with phase inverter and a few preamp tubes.
EDY19
Fri Mar 17 2006, 12:01PM
Im going to stick with a preamplifier so i dont have to go out and buy a large output transformer, and iim trying to stick with the tubes i have, so I don't want to do a push pull because i don't have multiples of any power tubes.
