  • Guests: 70
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Switching before zero cross
Fri May 16 2008, 01:27PM Print
I'm designing feedback for an inverter. The feedback is a voltage sine wave.
Is there a simple way to make the switch happen an adjustable time before the sine wave crosses zero, without using a PLL?
Berni
Fri May 16 2008, 04:45PM
Berni Registered Member #1132 Joined: Mon Nov 19 2007, 06:15PM
A comparator and a potenciometer?
Fri May 16 2008, 06:55PM
Berni wrote ...
umm.. no, I need it to switch before both 'pos-to-neg' and 'neg-to-pos' zero crossings, you cannot do this with a comparator...
Mathias
Fri May 16 2008, 07:32PM
Mathias Registered Member #1381 Joined: Fri Mar 07 2008, 05:24PM
why not?
F3
GeordieBoy
Fri May 16 2008, 08:02PM
Hi Jan, Yes you can do what you require without using a PLL. At first it appears that the required circuit must be able to "see into the future" to predict the zero-crossings before they actually happens...
Fortunately you can actually achieve this effect by adding a small amount of the derivative of the sinewave to the sinewave before feeding it to a normal comparator. Because the derivative of a sinewave leads it by 90 degrees you are actually introducing a small phase-lead by adding in a derivative component. This will make the comparator toggle early.
Or alternatively you can add a small amount of the integral of the sinewave to the reference level defining the comparators switching threshold. Since the integral lags by 90 degrees but is effecting the threshold instead of the signal the net effect is the same.
Both of these techniques will achieve the desired result although the actual amount of phase lead or lag may need to be fine-tuned to get the comparator to toggle the desired number of ns early that you want at the chosen operating frequency.
-Richie,
Sat May 17 2008, 07:27AM
Thanks Richie, that's something along what I was thinking.
However I'm not sure how to implement it. The problem is that the feedback frequency is not constant. A simple phase shift could be done with a RC element, but the shift would be heavily dependent on frequency.
Sat May 17 2008, 08:03AM
I think the shift would be only weakly dependent on frequency. 6dB/octave and all that.
Like Richie said, it's not exactly hard to predict what a sine wave is going to do next wink
GeordieBoy
Sat May 17 2008, 02:11PM
Yes, as you said you can achieve a +90 degree phase-lead well below Fc with a first order high-pass filter, but with a dramatic drop in signal amplitude. Or alternatively a -90 degree phase-lag well above Fc for the 1st order low-pass filter.
If you need to process a signal to introduce variable phase-lead or lag WITHOUT altering the amplitude there is also something called the all-pass filter. This will give you an adjustable phase shift without the accompanying low-pass, band-pass or high-pass amplitude characteristic:
This circuit is used in guitar phaser pedals to shift the relative phases of harmonics without messing with the amplitude. Since it doesnt cause an amplitude change, you can cascade allpass filters to get as much phase shift as you want.
I guess it is as good a "see into the future" circuit as you can get with analogue electronics! If anyone knows of a better one, let me know as I have a plan involving such a circuit, a cheap radio, and next week's lottery results. wink
-Richie,
Mon May 19 2008, 08:46PM
Going back to this... I think it would be best to make it switch adjustable time before the zero crossing, but this "pre-delay" should not be frequency dependent.
Is this possible with a PLL or in any other way?
