  • Guests: 36
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
MOSFET
Linas
Fri May 16 2008, 08:03AM Print
Hi,
i am ,making 8KW SMPS + induction heater
so i need mosfet body diode blocking system, i believe, that i going to use 100KHz
mosfet are 88A FDH44N50*2
and does they are good ?
ULTRAFAST HIGH VOLTAGE RECTIFIER
POWER SCHOTTKY RECTIFIER
Thank you for help smile
Fri May 16 2008, 01:14PM
I doubt you'll have any problems with the mosfet body diodes at 100khz...
Mathias
Fri May 16 2008, 07:24PM
Mathias Registered Member #1381 Joined: Fri Mar 07 2008, 05:24PM
at 100khz the period of a cycle is 10microsec , i doubt there would be any problem cause of the body diode's recovery time :)
