  • Guests: 62
01/13 si2030 (62)
flash switch
Solidacid
Thu May 15 2008, 07:47AM Print
Solidacid Registered Member #1430 Joined: Sun Apr 06 2008, 11:12AM
hey everyone.
i have been using the flash of a disposable camera as a coilgun trigger(hook the capacitors to the tube and flash it) for a while, one of my friends told me im losing a lot of energy this way, is it better to just touch the wires together?
Bjørn
Thu May 15 2008, 09:56AM
Yes, the flash tube is designed to radiate away as much energy as possible as light. Just about any mechanical switch will be more efficient.
flannelhead
Thu May 15 2008, 01:01PM
I can agree to all that Bjørn said. In my first coilgun I used flash switch too, but man was the efficiency poor! Buying a SCR is highly suggested, but if you can't get one, you could also use a quite heavy (some Amps@230V) mechanical switch for low energy systems (<50J)
zephir
Thu May 15 2008, 07:05PM
zephir Registered Member #1471 Joined: Tue May 06 2008, 03:17AM
isn't there a manual switch on the disposable camera, you know, when you press the take photo button it would not only trigger the shutters but also trigger a mechanical switch? There should be something like that on the board. Its a low voltage contact switch, you can use any regular switch in its place by soldering wire to it, connecting up any switch of your choice. For my first coil gun I just bought a small pushbutton from radio shack to use as a trigger. I soldered some wires to the contacts on the board, and soldered the wires to the pushbutton.
just use that instead of the flash tube. In fact, remove the tube altogether.
What i did for my coil gun i removed the tube, and put my coil in its place. The coil is triggered only by the mechanical contact switch on the board.
Myke
Fri May 16 2008, 12:55AM
zephir wrote ...
The coil doesn't need a trigger. If you just put it in the place of the flash tube then it goes directly across the capacitor and the trigger won't do anything. The flash tube has a very high resistance before the gas inside it has ionized. A coil will have a low resistance.
Mechanical switches work well. To increase the efficiency, you would want the switch to close as fast as possible. You also don't want the contacts to bounce.
Fri May 16 2008, 09:22PM
Also the flash tube can shatter at high power.
