  • Guests: 31
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
Dissassemble of transformer with... ?
dingo27
Tue May 13 2008, 09:12PM Print
dingo27 Registered Member #890 Joined: Tue Jul 10 2007, 10:06PM
Hi, because i dont have posibility to buy skelet of trafo, i want to use my "not usable" trafos. but they are glued with some kind of laquer. What can i use to melt it and get away, so i can safetly dissasemble?
(sorry for some words... i dont know if i used the right ones)
THANKS for any advices (but not to buy them on ebay :)
Firefox
Tue May 13 2008, 09:35PM
Firefox Registered Member #1389 Joined: Thu Mar 13 2008, 12:50AM
Most of the time the glue will come apart if you boil it for a few minutes. If your transformer is laminated iron, you're in luck, as those are very hard to break, and the glue is usually somewhat easy to get off. If it is ferrite, its a bit tougher to get apart without breaking the core. If you are having trouble getting it off the glue, take it out of the water, scrape as much glue off as you can, then put it back in for awhile. Rinse, lather, repeat.
Wed May 14 2008, 01:50AM
Well for my laminated iron transformer i just got a sharp edged object(in this case a knife) and pried the laminations apart. I had to do this 50 or more times and i had disassembled my first transformer! amazed
Experimentonomen
Wed May 14 2008, 04:27PM
Where i work we heat the transformers in about 150c in a oven when we need to disassamble them.
