  • Guests: 41
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
Feedback for current control
Linas
Sat May 10 2008, 09:18AM Print
Hi all
I am making 8KW smps for welding+induction heating
i need to make current control, i don't know, how to make,
i think use CT front of power transformer (Imax=25.5A Imin 0.3A)
so how tu make it, please, some one show real circuit for my case cry
power should be regulated by trimmer resistor confused (in control panel)
here is my idea, which is rubbish
(control circuit does not chow real circuit, just PWM is how i going to make it)
1210411111 1143 FT0 Current
GeordieBoy
Sat May 10 2008, 10:34AM
You would usually put the burden resistor Rs after the rectifier bridge instead of directly across the secondary of the CT. Otherwise the forward-drop of the diodes in the bridge causes a dead-band in the current sense signal. For small values of Rs insufficient voltage can be developed to forward bias the diode bridge.
By placing the burden resistor after the rectifier, the CT secondary develops whatever voltage is required to forward bias the diodes and drive current through Rs. Therefore no dead-band.
-Richie,
Linas
Sat May 10 2008, 01:17PM
i know, i pleasing to much, but can someone correct my schematic ? (replacing parts etc..) frown
well, now is better idea showing than before neutral
1210456133 1143 FT44956 Current
