  • Guests: 54
How to measure voltage of capacitors
OwlFowl
Thu May 08 2008, 07:52PM Print
OwlFowl Registered Member #1441 Joined: Sun Apr 13 2008, 03:40PM
Hello,
I borrowed a multimeter from someone so I could use it to measure the voltage stored in the capacitor bank. I don't want to blow it up, so how would I go about measuring the capacitor voltage while it's charging?
I'm guessing it's just +ve to +ve and -ve and -ve. Should I just wire it like this ?
Thu May 08 2008, 09:03PM
Yes.
Getting a more fundamental understanding of electronics might be a good idea before playing with potentially lethal capacitors. (pun not intended)
Shaun
Fri May 09 2008, 01:51AM
Well that link you gave is for measuring capacitance, which you should already know since its printed on you capacitors (hopefully). For measuring the voltage your bank is charged to, yes you would put the meter in parallel with the capacitors (thats black probe to -, red to +).
pbfree
Thu May 15 2008, 06:07AM
pbfree Registered Member #1386 Joined: Tue Mar 11 2008, 08:16AM
Remember not to fiddle with the meter if connected to a charged bank. You may switch it to current mode or some mode that ends up forming a short across the LOAD!
Practice on a $10 meter. Practice using the meter over batteries first. Insert a high wattage low value resistor in series with the probe lead then intentionally put the meter in current mode across a battery. When you feel the heat and possible some smoke based on the battery supply and the chosen current limiting resistor, know that this is but a fraction of what will happen if you mess around with high voltage capacitors lacking full knowledge of how to measure and deal with them.
