  • Guests: 26
GhostlyFigures (36)
10/06 Ivan Kalafatic (17)
10/07 Pyromaniac (34)
10/07 Wavetuner (76)
induction heater resonance
1 2 3 4
Linas
Wed May 07 2008, 11:20AM Print
Hi all
does need in induction heater resonance, i will use step down transformer to 80V and then will be work coil, so is resonance make heat faster, and power will be bigger ??
because i want to use fixed frequency neutral
work coil
1203346341 1143 FT0 P1360634
cap:
1210159211 1143 FT0 P1400020
Wed May 07 2008, 07:55PM
Fixed frequency and resonance works fine. I have had good results and so have many others. Link2 Resonance is used to allow much higher currents to pass through the work coil, which are necessary for induction heating. Take my heater for example. A half-bridge run from 320V gives +/-160V on the transformer primary. With a step-down ratio of say 20, a work coil inductance of around 3µH and frequency of 150kHz. That's 8V over 2.8 ohms of inductive reactance, so 2.8A of current. Nowhere near enough for induction heating. Add series resonance and the work coil reactance is suddenly zero, viola! more than enough current.
Linas
Sun Jun 29 2008, 03:27PM
finally, i made induction heater, i use 1uF wima FKP1 650Vdc cap, power transformer 20:1, resonance frequency 160KHz, driving half-bridge by FDH44N50 mosfet's, fixed frequency
1214753225 1143 FT44780 P1430005
Marko
Sun Jun 29 2008, 04:01PM
Linas wrote ...
Hey, nice work sir! You definitely need a water cooled coil now, take care not to destroy your inverter.
What core are you using for the impedance matching transformer, it looks fairly large?
Some thoughts about the circuit:
- You don't really need the additional external freewheeling diodes, but it's OK to keep them. You just need to tune slightly higher than resonance, and take care the circuit remains so, in which case diodes are completely useless and just waste power on series Schottky's.
For driving inductive loads, the diodes just aren't needed - internal diodes in the MOSFET's are completely fine into many hundreds of kHz as they suffer no forced recovery with inductive loads.
In case you are using feedback, you will need to provide some commutating current by slightly gapping your matching transformer.
- your capacitor looks fairly robust, but you might want to space it out and introduce forced air cooling.
Linas
Sun Jun 29 2008, 04:25PM
capacitor are very good, he don't even warm, transformer are 3F3 material, 6*3Cm, he is using in my 8KW inverter (20V 400A), i don't know how to make feedback, because with toroid, 1om resistor burns just in 1secund...
Now i am using bigger work coil, in work, he just go hot, not red cheesey
And one more thing, i can't make metal white :(
Experimentonomen
Sun Jun 29 2008, 06:16PM
To reach that temperature, you need feedback to track the resonant frequency, as it changes as the work piece heat.
Linas
Wed Jul 02 2008, 06:41AM
which feedback is best in induction heater Voltage~current zero crossing detector ...?
can i connect CT direct to my driver ?? (CT>>1K resistor>>0,1uF capacitor>>dumping diodes(1N4148)>>74HC14) ?? (t will generate up to 1KV but i believe resistor and diodes make logic level signal mistrust
Hernan
Tue Aug 05 2008, 12:32PM
Hernan Registered Member #1614 Joined: Wed Jul 30 2008, 03:08PM
Hi, I'm new in the forum. I'm making an induction heater .I want to reach 4 to 5 KW using a full bridge voltage sourse inverter to drive ferrite isolating 1:1 transformer with LCLR resonant tank.for the moment I'm using half bridge inverter with Mosfets IRFP460 for testing but I would like to use large rating switches ..
when I reached 10A In mains input current the mosfet driver Ir 2110 failed and the power mosfets too.I will use a small ferrite to drive mosfets to isolate the control electronics.I also would like to use a PLL to track the resonant freq.
here is a picture
1217939522 1614 FT44780 100 0749
1217939522 1614 FT44780 100 0752
1217939522 1614 FT44780 100 0757
Myke
Tue Aug 05 2008, 05:58PM
It seems like the caps should be connected directly to the work coil... Also try to minimize wire length as that introduces stray inductance.
Tue Aug 05 2008, 06:20PM
I would assume that us is using some conduction cooled caps (the black blocks) between the 2 copper plates. The bank of electrolytics is just energy storage for the DC bus.
If your mosfet driver failed then it is probably time to get a better one wink The ir2110 wasn't designed for this kind of abuse, you would be better of with some ixdd414 or the likes.
