  • Guests: 43
Rail gun help- projectile and rails
zephir
Tue May 06 2008, 04:00AM Print
zephir Registered Member #1471 Joined: Tue May 06 2008, 03:17AM
I've been building my rail gun project for 2 years now, I got my capacitors, I figured out how to charge them, I figured out my trigger, I got the injector design done, but I don't know how to do the rails or what projectile I should use.
I'm really on a very small budget and don't have access to any machine tools. All I have is a electric drill, hacksaw, soldering torch/iron, file, and screwdrivers.
I need suggestions on what kind of projectile I should use and how to make the rails.
I've been thinking about using bullets from reloading as a projectile, they're copper jacketed and easy to get 1000's of. any thoughts on that?
thanks.
Shaun
Tue May 06 2008, 04:23AM
Round projectiles are tough to use with the flat rails, since they need to be in *extremely* good contact with the rails, otherwise you will completely f**k them up and possibly spot-weld your projectile to them.
What type of capacitors are you using? What is the stored energy? Can you post some pics?
zephir
Tue May 06 2008, 04:39AM
what about round rails, could i use a pipe, cut it up so there is better contact?
I got my capacitors online
I bought 12 of them for 5.95 each last year.
400v 3900uF, or 312 joules.
I'm planning on either wiring them all parallel so its 400v 46.8mF total or series-parallel for 1200v 5200uF.
