  • Guests: 55
OBIT VA Ratings?
Billybobjoe
Mon May 05 2008, 08:27PM Print
I've been looking at oil burner ignition transformers and apparently now there are the "electronic" type (solid state) that output high frequency, but without the GFI annoyances or SSNST's (or so I assume, considering they are made to be practically short circuited).
However I stumbled upon this picture:
813a 1 Sbl
Misprint, some magical device that breaks conservation of energy, extremely bad power factor cheesey? Or maybe voltage just drops drastically (to about 1100 volts?) as it is loaded?
Mon May 05 2008, 08:51PM
The only thing I can think of is that if it's a switching PSU type, the reactive power circulates only in the primary circuits and the filter capacitor, input power from mains is only the real power. So maybe the stated input power is with a (short) arc on the output (as you say voltage drops considerably).
OZZY
Tue May 06 2008, 05:22PM
OZZY Registered Member #511 Joined: Sat Feb 10 2007, 11:36AM
The output ratings for an OBIT are Max voltage open circuit and Max current short circuit. The power rating is given at the input in VA. The iron core transformers have high leakage inductance, this lets the voltage droop as the load is increased. The solid state transformers operate at about 20KHz and probably use electronic current limiting.
OZZY
