  • Guests: 42
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
Gate Drive CM600 CM300's
Derek_L
Fri May 02 2008, 10:00PM Print
Derek_L Registered Member #1125 Joined: Fri Nov 16 2007, 09:13PM
I know Dan has this great page
but I cannot find the IXDN430CI anywhere.
Anyone know of where I can get this?
Digikey does have the IXDD414CI-ND @ 14amps drive
How much gate current is actually needed on the bigger igbt's.
I could double up the IXDD414 but since they dont look to be a super popular item i might run into the same problem as the 430's if I blow a couple.
Thanks for the input,
Derek L
Derek_L
Tue May 06 2008, 08:37PM
Found ixdd414CI's
Can anyone tell me thier typical gate currents on teh cm300's, cm600's or a good procedure to test use?
Dump 120VDC into 100 watt light bulb and up the gate current from 1 amp until switching speed is within spec?
Thanks,
Derek L
Tue May 06 2008, 10:49PM
There is a good application on on how to gate drive a CM600 from Powerex. Check it out on their website. It shows how to operate, design, and test the gate drive.
Basically, get your gate drive running, and then (with no collector voltage on the IGBT), switch the CM600 and measure risetime/fall time and look at the waveform with an oscilloscope.
Wirenut
Thu May 08 2008, 12:10AM
Wirenut Registered Member #141 Joined: Sat Feb 11 2006, 01:14PM
IXDN430CI is available here:
Found via octopart Link2
Derek_L
Thu May 08 2008, 02:23AM
hehe thanks Dan.
I didnt know you were dr shock :) nice nick.
Derek_L
Thu May 08 2008, 05:57PM
Just a heads up I belive this is what dan was talkinga bout
Page A46 is some great stuff
