  • Guests: 49
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
TL494 duty cycle
Sat Apr 26 2008, 08:24AM Print
I am trying to wire the tl494 so that zero control voltage=zero duty cycle (and increasing the voltage increases the d.c. linearily). So far any combination I have tried results in zero control voltage=maximum duty cycle. Any ideas how to wire it up?
1209198218 152 FT0 Tl494
Sat Apr 26 2008, 10:03AM
Is there any reason you can't use the internal comparators instead? Otherwise I would use a differential amplifier to make an inverter of sorts, so 0-1.2V on the input gives 1.2-0V on the output.
Sat Apr 26 2008, 10:10AM
Uhzsaurs wrote ...
Ok, so let's say I am an op-amp n00b tongue How would I go around making an "inverter" with the internal comparators? I wonder if there would be any problems with the diodes on their outputs.
Sat Apr 26 2008, 12:48PM
It would be harder with the internal comparators, but they could be used to manipulate the duty cycle directly instead. Like shown here Link2 . You might have to short pin 1 and 3 instead to get what you want, and feed the pot to pin 2. (making it an inverting amplifier)
If you used an external op-amp: wire it like a differential amplifier with 1.2V on the positive input and 0-1.2V on the negative input, and feed the output to pin 4.
Sat Apr 26 2008, 02:42PM
After a lot of experimentation, it worked like this (only the important part is shown):
1209220888 152 FT44210 Tl494 Dutycycle
