  • Guests: 34
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
thyristor
rp181
Fri Apr 25 2008, 09:46PM Print
I recently obtained a thyristor, how can i tell the terminals and what they are (gate? etc...)
Datasheet: Link2
imtihnking small red and white are trigger wires, case is cathode, big red anode.
EDIT: got it. it is what i said, but to find, i put a cheap 10$ DVM to the white and red. is there any chance that i burned it by overloading gate?
Electroholic
Fri Apr 25 2008, 10:31PM
gate is not dielectric, it will take quite a bit of current to damage it. I bet you are fine.
rp181
Fri Apr 25 2008, 10:44PM
i think so too, i tested the main leads, there not connected(open circuit)
Bjørn
Sat Apr 26 2008, 12:33AM
The datasheet you linked to says:
Thick red = Cathode
Thin red = Auxillary cathode
White = Gate
rp181
Sat Apr 26 2008, 12:58AM
First time working with SCR's, Whats the auxillary cathode? is it to trigger it, you apply voltage to withe throught thin Red, and that allows the anode (case) to conduct to the thick red?
Also, what kind of diode will i need to protect it from backflow, does it need to be High-speed?
Sorry for so many questions.
Well i tested it, i applied 16v with a 220 ohm resistor to the gate, it closes =)
Any idea how much this SCR is worth? i saw a guy on ebay selling 780$, but that is WAY overpriced. This is for a school project, so i wanted to give the company who gave it to me proper credit.
How high would i be able to go in uF at 1000v? i played with barry's RLC sim, but what is the highest capacitance i could go for 5000A short circuit current?
Shaun
Sat Apr 26 2008, 03:54AM
The auxiliary cathode is connected the exact same way as the regular cathode; its just separate so you can connect the gate and cathode to your control circuit easily, leaving the regular cathode for the high-current path. You should be able to test continuity between the two.
rp181
Sat Apr 26 2008, 02:39PM
Just tried it and got it to "work". To trigger, im using a 16.5v laptop supply with a 220 ohm resistor in seris.
rp181
Mon Apr 28 2008, 12:37AM
will submerging i in oil be a good idea instead of a heatsink
Electroholic
Mon Apr 28 2008, 12:48AM
if you are only using it as a coil gun switch, heat will not be a problem.
