  • Guests: 201
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
Film Caps Changing Value Over Time
tesla500
Fri Apr 25 2008, 07:45PM Print
tesla500 Registered Member #347 Joined: Sat Mar 25 2006, 08:26AM
Hey guys,
Have any of you seen dry film caps change value over time? I've got a metal halide light fixture that started killing bulbs, and I found the 10uF 400VAC film cap in series with the lamp has decreased to 8uF. I'm puzzled as to why, I've never heard of this happening before.
I cut the capacitor in half, it's of rolled construction. The dielectric appears to be black, and I couldn't see any metalization, so the metal film must be very thin.
David
Dr. Shark
Fri Apr 25 2008, 09:26PM
Did you measure the capacitor before it "changed value"? 20% tolerance is not unheard of, so it may just have started out with just 8uF. If it was a self-healing capacitor (likely from your description), it could have been overvolted several times, which would decrease the capacitance somewhat, but that would be rather obvious when you unroll it.
tesla500
Fri Apr 25 2008, 11:14PM
These are +/- 5% caps, and I'm sure they're changing. I don't know the original capacitance of the one that's now 8uF, but after that one failed, I put in another one, same type, out of an identical fixture that was unused. It measured over 10uF originally, and just recently I checked it, it's now down to 9uF.
It may be that it's a very poor quality self-healing cap, the fixtures and caps are Grandlite brand out of China. I'll have a go at unrolling it.
David
Backyard Skunkworks
Sat Apr 26 2008, 04:33AM
The +/- 5% rating is not likely indefinite, I know even top shelf resistors vary about 1% after a few thousand hours so I'd guess the same thing holds true for caps. I don't know why this is happening but I can say that I doubt its out of spec, a lot of datasheets seem to say "Its +/- x% for y hours, then we dont have a clue what the heck it does".
tesla500
Sat Apr 26 2008, 05:51AM
You could be right about the tolerance/time spec. Clearly the spec'd caps weren't good enough. The cap killed the original bulb before the bulb died on it's own.
David
Sat Apr 26 2008, 06:03AM
Perhaps get a higher voltage rated capacitor in there. The 20% loss in capacitance is *very* considerable for a film cap and is very likely NOT within spec. Id agree in the assessment that these capacitors are failing from dielectric punch-through. If the capacitance begins to wander out of the specified range, then its likely on the edge of complete failure.
