  • Guests: 74
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
Saturable reactor from isolation transformer
Fri Apr 25 2008, 02:07PM Print
Would this work?
1209132410 152 FT0 Reactor
Dr. Shark
Fri Apr 25 2008, 06:39PM
Depends.
If the isolation transformer has 1:1 turns ratio, there would be no AC on the "DC control" tab, but on my (small) iso. xformer the ratio is quite far from 1:1 to compensate for losses.
Fri Apr 25 2008, 07:03PM
Well, my transformer is a beast, probably over 1KVA. I guess it is pretty close to (or exactly) 1:1 ratio.
So would it work assuming the turns ratio is 1:1 (so there is no ac component on the control input)?
tesla500
Fri Apr 25 2008, 07:31PM
tesla500 Registered Member #347 Joined: Sat Mar 25 2006, 08:26AM
That won't work, unfortunately. The DC current flows through both windings in opposite direcitons, so the MMFs generated will cancel, and the core won't see any flux due to the DC.
David
