  • Guests: 28
09/29 Ultra7 (55)
09/29 uitvinderalex (37)
09/30 Terrorhertz (16)
How does a coin slot work?
General_Norris
Wed Apr 23 2008, 04:46PM Print
General_Norris Registered Member #1405 Joined: Wed Mar 19 2008, 10:57AM
I have surfed the net for information but I have not found even a basic idea of how this works. I think they weight, size and measure magnetically the coins, but I have no idea how and the lack of information is bugging me.
Anyone know how they work?
Wed Apr 23 2008, 04:53PM
Its a combination. Size, weight, magnetically. Basically size is compared, weight compared, and then a magnet is used to pull any coins which are ferrous in nature. Very simple, but effective. There may be other sensors depending on the complexity, but for the most part, its a very simple mechanical discriminating device.
Bored Chemist
Wed Apr 23 2008, 04:59PM
Size is cheched by rolling the coin over a hole that it shouldn't fit through (if it drops through, it's too small) and then through a hole that's just bigger than it (an oversized coin won't fit).
Weight is checked by roling it down a spring loaded slope. If it's too heavy or too light the spring doesnt flex to the right degree so the coin doesn't follow the right path.
Sending the coin past a magnet will check if it's magnetic or not and (roughly) how magnetic it is.
All that without any electronics.
General_Norris
Wed Apr 23 2008, 06:20PM
Wow, that's smart. And I guess that for electronical devices they have some kind of transductor so the machine gets a credit when the coin reaches the end, doesn't it?
Bjørn
Wed Apr 23 2008, 11:01PM
Tim Hunkin has some information here: Link2
Often there is no need for a complicated sensor for amateurs like us, unless the machine gives out something valuable that can be turned into money in a fast and simple operation there will not be many cheaters.
Thu Apr 24 2008, 09:02AM
I made a coin slot mechanism for a college project. As the coin rolled down a chute, we used two magnetic sensors to measure the thickness and composition of it, a lamp and CCD line camera to measure the diameter, and a lookup table programmed into an EEPROM to figure out what kind of coin it was based on those three measurements.
It worked pretty well, and could recognise all of the UK coins, while rejecting foreign coins and washers. Of course it helped that we had a friend whose job was servicing coin-op machines, and he gave us some dead mechanisms to reverse engineer...
