  • Guests: 42
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
Running laminated transformers on higher frequencies
Sat Apr 12 2008, 04:18PM Print
Is there any problem with running a laminated mains transformer above its operating frequency? I guess the core hysteresis loss will increase but will this be a problem? I have no idea about the core loss when operated at "designed" frequency but I can imagine that the copper loss dominates (provided you do not saturate the core).
What do you think?
Lakeowner
Sat Apr 12 2008, 05:22PM
Lakeowner Registered Member #1370 Joined: Mon Mar 03 2008, 09:01AM
With enough low frequencies it may work (at AF), but you can't probably push lots of power through it. How high frequency did you imagine?
Sat Apr 12 2008, 05:29PM
For a 50Hz transformer, I meant something like 100-200Hz for 2x to 4x more power (voltage) from the same sized transformer.
Lakeowner
Sat Apr 12 2008, 06:36PM
I have ran such transformer at about 400Hz, and it worked fine for a moment at about 15x voltage. It seemed to work at the viewpoint of core, but windings didn't of course stand it. Iron laminate is used in audio transformers.
Dr. Slack
Sat Apr 12 2008, 08:35PM
Core losses rise at higher frequency due to both eddy currents in the lams, and tracing out the hysteresis curve more times per second. If you are after only intermittent operation and not worried about efficency, then running at 2x to 4x frequency ought to give you 2x to 4x the power output until you overheat, you should get minutes per run at only 4x. However dropping the peak flux by dropping the volts will bring the core losses back down as the sqaure, so perhaps 4x frequency with 75% voltage, you'll still get an increase in power, but longer run time and better efficiency. BTW, 400Hz aircraft trasnformers use very thin lams and a decent grade iron.
GeordieBoy
Sun Apr 13 2008, 01:10AM
In general the iron and copper losses will be similar in most power transformers of reasonable size. As Neil said, core losses are built up of hysteresis loss and eddy current losses.
Running transformers at a higher frequency can also make the leakage inductance more problematic because it represents a higher impedance at the new operating frequency. (So for instance if you ran an MOT at a higher operating frequency you would expect the output s/c current to be lower for the same applied voltage because of the higher series reactance at the new operating frequency.) At frequencies much higher than the intended operating frequency you may also find parasitic resonances caused by the inter-layer capacitances of the windings.
-Richie,
Sun Apr 13 2008, 02:45AM
Well i doubt this helps any but i ran an mot on 50 volts and got about 5kv from it at around 100-500 hertz and it was a 60hz 120 volt mot.
Myke
Sun Apr 13 2008, 06:21AM
I think that someone here found that around 400Hz is best for MOTs.
Sun Apr 13 2008, 06:43AM
Well my idea was to get more continouos power from a transformer. If the core loss would be too high then there is no reason for doing that.
lpfthings
Sun Apr 13 2008, 11:00AM
lpfthings Registered Member #1361 Joined: Thu Feb 28 2008, 10:57AM
I think the manufacturer would optimise the transformer for the frequency it is designed for, but running them at higher frequencies should be OK
