  • Guests: 42
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
Charging a 3 cell Li-ion batter pack from a USB port
Thu Apr 10 2008, 06:16AM Print
I am working on building the 4th revision of my GPS Tracker, and this time i am trying to integrate the batteries down onto the pcb so that there aren't any loose connections to screw me over this time...
Also, to keep things simple, I am having the mess charge itself over usb, which limits my charging voltage to 5v (ie, 1 li-ion cell)
This isn't problem for the main electronics, but I am hoping to also integrate a battery to fire the pyro loads--which really should be at least 2 or possibly 3 cells in series. Now in theory this should be downright easy, since most of the lithium ion chargers are already a buck converter, making one a boost converter one should be trivial... But i can't find any chips that let you do that angry
So short of having a 5v->13v boost converter followed by a buck converter based charger chip, is there an easier way to do this? I am only using small cells (probably 100ma/hr), but am very tight on pcb space. I also try to avoid leadless parts like the devil.
Thanks!
Dr. Slack
Thu Apr 10 2008, 07:11AM
The first thing that comes to mind is to control the charge yourself and use a standard boost converter PSU with a current limited, constant voltage, output (I'm sure they're all over the Maxim and LinearTech sites). I've had a quick look in the Wiki, and under "battery" there is a link to batteryuniversity which gives Lion charging as constant 4.2v/cell for max charge, 4.1v/cell for max life, and terminate when the charge current has dropped to <3%. The PSU handles stage 1 (constant current) and stage 2 (constant voltage) parts of the charge, just leaving you with either checking the charge current from time to time and turning it off, or having a current measurement feature which latches the supply 'on'. I have a suggestion for the current latch if needed.
You might want to do a bit more research into Lion charging specs than my 2 minutes' worth, especially for your specific manufacturer, before you knacker your batteries with an inappropriate profile.
The Wiki could probably do with a dedicated "rechargable battery" page giving a quick summary of the various types.
Electroholic
Thu Apr 10 2008, 09:21AM
Did you look at the LT1512 from Linear Technology?
Thu Apr 10 2008, 05:29PM
Thats the chip I was looking for, thanks!
