  • Guests: 35
HVDC capacitor charging time
iRET
Thu Apr 10 2008, 03:03AM Print
iRET Registered Member #258 Joined: Sun Feb 26 2006, 03:58PM
Hi,
How to compute the total time required to give the capacitor a full charge?
For example:
Power source: NST 9kv 25mA (bridge rectified)
Capacitor: 3kv 10uF
Cheers
Thu Apr 10 2008, 03:27AM
Becasuse you are using a constant current source (.025A NST), you simple consider the amount of charge stored on the capacitor (Q=CV) keeping in mind that 1A=1C/s
So to charge a 10x10^-5F capacitor to 3000v, you need .03C of energy, which at a charge rate of .025C/s will take 1.2 seconda
Shaun
Thu Apr 10 2008, 04:44AM
careful here, 1.2s is short and god knows what your capacitor will do if you accidentally charge it to 13kV.
Coronafix
Thu Apr 10 2008, 05:49AM
You want to charge a 3kV capacitor with 9kV????
iRET
Fri Apr 11 2008, 01:28AM
Sorry it should be 4 unit of 3kv caps. Total cap bank voltage of 12kv 10uF.
