  • Guests: 47
Lyonel Baum (77)
Mattc1886 (17)
01/09 RickR (18)
01/09 TheBoozer (58)
01/09 invader (50)
Help with first coil gun
NoooobToHV
Sat Apr 05 2008, 08:59PM Print
NoooobToHV Registered Member #1356 Joined: Tue Feb 26 2008, 12:02AM
Hey I just made a photo cap coil gun. It uses three 330V 120uF caps in parallel, no diodes no SCRs nothing like that. The only thing is i can not get the Caps to discharge. The coil is 100 Turns in a little less than a a inch and 22 gauge magnet wire. Any one know why the caps wont discharge?
All help is appreated
Thanks
Gnarly
rp181
Sat Apr 05 2008, 10:40PM
First of 100 turns is way to much (im fairly sure). Low number of windings with thicker wire is generally better.
Check your connections over again, and if u have one, use a voltmeter to see if the caps are even charging. When you fire and nothing happens but cap was discharged, you probably have a bad projectile placement, or its to heavy for your power.
Electroholic
Sun Apr 06 2008, 12:09AM
100turns is fine. but you would probably wnat to strip the insulation off the magnet wires.
EDY19
Sun Apr 06 2008, 12:56AM
How are you charging the capacitors? How are you triggering them to discharge into the coil? Getting the capacitors to discharge should be a simple task of putting something conductive across the terminals, so a little description of your setup would be very helpful in figuring out your problem.
FireBird
Sun Apr 06 2008, 01:04AM
FireBird Registered Member #1104 Joined: Tue Nov 06 2007, 07:38PM
Without some more information or a picture or something it will be hard to help. You should make sure your caps are even charging. If you have the coil connected directly to the caps, it will not charge. You need some form of a switch, even if it is as simple as touching two wires together.
Lakeowner
Sun Apr 06 2008, 10:13AM
Lakeowner Registered Member #1370 Joined: Mon Mar 03 2008, 09:01AM
After you have necessary system for charging, think how to protect your caps. Get at least a diode across the cap bank. It's strongly recommended because coil (inductor) will otherwise charge your bank to negative voltage. Electrolytic caps won't like that.
NoooobToHV
Mon Apr 07 2008, 04:25PM
I just took a picture ill get it up soon ... as for the caps i know theyre charging because i can decharge them with a pair of pylers and it makes a nice and big bang with a light show. As for charging them i rigged the charger from the camara to charge them. Finally i do have a switch and i have a 220 ohm resistor to increase the current ... The coil is enameled magent wire though ... could it not be firing because i havent shaved enough of the enamel off. as for the comment that the person said 100 turns was to much isnt the Resistance of the accual coil negiable?
Edit: I have no idea why i said the resistor to increase the current ... what i ment to say was that the resistor is there to because me and my friend were looking at it and we thoguht i wasnt firing because there wasnt a large enough potential difffernce ... secondly the switch isnt rated for ne thing above 10 A so we tried to decrease the amperage so it wouldnt blow the switch
NoooobToHV
Mon Apr 07 2008, 04:40PM
Heres a picture
1207586418 1356 FT42764 Cg
Lakeowner
Mon Apr 07 2008, 05:40PM
Your caps are quite small. Don't expect too much energy :). Also, don't use any kind of resistor between cap and shooting coil. The whole point of coilgun is to discharge cap through an inductor _fast_. Even little resistance (say 10 ohms) decrease performance well. When dealing with low voltages, minimizing resistances becomes extremely important.
Andyman
Mon Apr 07 2008, 07:22PM
I'm a little surprised that the resistor hasn't exploded. cheesey All its doing is annihilating your efficiency. There might as well not even be a coil there. The resistor is taking the current and turning it from a potentially high current millisecond pulse into a low current, slow bleed off of the caps.
Bottom line - get that resistor outta there, pronto! Or at least move it before the capacitors to act as a charging resistor.
Also, try making a mechanical switch instead. It will handle alot more current. For my first switch, I simply got a thick copper wire (like 14 awg or something) and pounded it relatively flat. Then I used a soldering iron to solder on a lead from it, and at the same time melt it to a piece of acrylic (actually, it was a CD). For the other contact, I used one of the laminations from a small transformer with the black coating scraped off. I also melted that to the CD. Heres a picture of it.
