  • Guests: 218
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
TFT screen repairs
Wed Apr 02 2008, 07:45PM Print
Hi there.
Just finished fixing a pile of TFTs (mainly HP 17") and ran into a few interesting problems.
This one has suffered a failure of one of the two pairs of SMD 8 pin MOSFETs, apparently caused by the high ESR capacitor problem.
I've discovered that many monitors use basically the same 8-pin configuration, however this one worked for a while then failed again (it seems to be heat related). Have you run into this before?
I also saved all the bad capacitors, was looking into making up a kit of parts to fix the most common brands. Seems that 470uF 25V and 1000uF 16V, 1000uF 25V and 220uF 25V are used most often, and the ones which fail usually show their presence by the tops bulging.
However, it seems that if you see a single bulged capacitor it doesen't always mean adjacent intact parts are also faulty, best way to tell is by swapping the lot then saving the "spare" ones and testing later.
Also well worth checking for shorted C5706/5707 transistors in the inverter section, as well as dodgy >1M startup resistors. This fault is a royal pain and kills many otherwise good PC power supplies as well (cheap parts?!)
Back to this Dell 15" - the repaired inverter has severe signs of heating where the bad FET was, so perhaps other parts have been weakened. I had to repair a fine track on one corner... Observe.
UPDATE:- Unfortunately the repair didnt hold for long. However it does prove that the problem was indeed these parts, just need to find an exact replacement.
regards, -Andre
1207165501 96 FT0 Dell Fried
