  • Guests: 49
Alex_FX (45)
Pieznice29 (31)
12/31 Arjan EMM (52)
01/01 Bosko (56)
01/01 hen918 (30)
Rocket Triggered Lightning
1 2 3 4  last
Logan Kennedy
Tue Apr 01 2008, 08:18PM Print
Logan Kennedy Registered Member #1103 Joined: Mon Nov 05 2007, 06:02PM
I know lightning has been triggered by the use of rockets and high voltage. The wire & HV source is attached to a rocket, and then the rocket is ignited and proceeds to ascend until it triggers lightning.
What I'm wondering is at what altitude does the rocket have to fly before the lightning is triggered? Also, how much high voltage is needed to successfully trigger lightning? Also, last but not least, what are the possibilities of an "amateur" utilizing this method successfully?
EDY19
Tue Apr 01 2008, 08:35PM
I don't think you even need high voltage connected to the wire. I think a couple thousand volts is not very likely to be a trigger for millions of volts to create a conduction path to ground. Check out this site for a little bit of info:
Logan Kennedy
Tue Apr 01 2008, 09:08PM
Hmm, I would probably conduct this experiment out of the way of the public so as to not endanger anybody.
The current experiment I'm designing requires the use of lightning and the enormous amount of heat generated from the plasma.
It would be interesting to hear from some individuals that have first hand knowledge of these scientific experiments involving the triggering of lightning.
Bjørn
Some sites says that a charge builds up on the nosecone of the rocket as it flies. I have noticed that helicopters have a tendency to trigger lightning and they also build up a static charge.
One site mentions 600 metres of wire but since you can sometimes trigger lightnbing by waving a fishing rod around and other times it happens between very high clouds I guess it depends mostly on practical and local considerations.
The success depends mostly on launching the rocket at the right time, hopefully just before a natural strike would happen. Some sort of field strength measurements would be very helpful.
If there are regular thunder storms where you live I would say that it is not a hopelesss idea. It would involve some thought to make sure it is safe and probable quite a few tries before it works.
Logan Kennedy
Tue Apr 01 2008, 09:19PM
Hmm, very interesting. This experiment would probably be best conducted in a barren field or at a site with high elevation.
wrote ...
To induce lightning, researchers have created a high-tech version of Ben Franklin's kite experiment. They attach a spool of copper-Kevlar wire to a chest-high rocket and affix the other end to a specially designed launch pad.
Then they wait for one of Florida's many summer thunderstorms to pass overhead and intensify.
When things get really gloomy, and lightning is on the verge of busting loose, the scientists shoot a rocket up about 2,000 feet (610 meters), Dwyer explained in a telephone interview. As expected, the storm takes advantage of the direct connection to the ground.
From what this article says, it should be fairly straight forward to obtain/design the needed equipment to trigger lightning.
Tesladownunder
Wed Apr 02 2008, 03:53AM
Logan Kennedy wrote ...
It's much cheaper, safer and reproducible to have a bank of pulse caps for your experiment. Lightning is of the order of 100kA plus if I recall although of much higher voltage and duration. You won't need 10MV if you only have an experiment in a small space. I achieve 100kA easily with my cap bank.
Are you willing to say what you have in mind?
(mind you it would be very cool to catch lightning)
TDU
Bjørn
Wed Apr 02 2008, 03:55AM
For most experiments, capcitors would make it much simpler. The reproducability alone is a huge improvement. There are some things like the x-ray/gamma radiation that will be difficult to study.
Ultra7
Wed Apr 02 2008, 04:41AM
Ultra7 Registered Member #1157 Joined: Thu Dec 06 2007, 12:11PM
Dude, Logan, I've got to drive out to your house one day and see all yer goods.
Maybe you and me need to do a Houston Teslathon.
Granted, I don't have any MEGAVOLT Uber Tesla coils, but I have a 6inch, a 4inch, and a mini SSTC.
Thats 3 at least.
Wed Apr 02 2008, 12:27PM
I wonder how small you could shrink a quarter with triggered lightning wink. I saw it done on TV once and they didn't charge the wire at all just attached it to a big metal frame on the ground. Their rig was pretty hit and miss, not every rocket got lightning.
Wed Apr 02 2008, 02:20PM
In Eastern Europe, they do the same thing with a model rocket and wire, and just launch them over powerlines. (Of course they're idiots), but there are lots of videos on youtube showing this dastardly feat of stupidness.
1 2 3 4  last
