  • Guests: 30
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
SCR "chopper" driver for mains xfmrs
Tue Apr 01 2008, 09:49AM Print
What if you made a SRC/TRIAC "chopper" circuit which passes only the second half of every halfwave, and used that to drive a mains xfmr with doubled volts per turn? Would that work?
Tue Apr 01 2008, 02:25PM
If you only passed half of the waveform the transformer would only get pulses of DC and would probably soon satrate... If you put a dc block cap in series with it you might be able to get away with it, but there are better ways...
Tue Apr 01 2008, 03:06PM
Which better ways do you mean?
I had something like this in mind, which is symmetric:
1207062364 152 FT42416 Waveform2
Tue Apr 01 2008, 03:07PM
Thats pretty much what a cheap light dimmer does.
teslacoolguy
Tue Apr 01 2008, 03:58PM
Steve Conner did something very similat to that Link2 Link2
Wed Apr 02 2008, 09:21AM
Well, I guess I did make that driver, but I never thought of using it in the way Plasmaddict suggested.
It's a clever idea, and I can't see any reason why it wouldn't work. People use light dimmers to drive ignition coils and induction coils all the time.
