  • Guests: 61
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Easiest way to power a Marx generator
General_Norris
Sun Mar 30 2008, 09:29PM Print
General_Norris Registered Member #1405 Joined: Wed Mar 19 2008, 10:57AM
5char
Because I don't have money for a neon sign transformer.
Kizmo
Sun Mar 30 2008, 09:55PM
that would be flyback transformer if you have access to old televisions
Myke
Mon Mar 31 2008, 04:07AM
A Marx needs DC. So the newer flybacks work.
You need AC for a CW multiplier.
Right?
Mon Mar 31 2008, 04:03PM
Right.
A small and simple 555 driver is all that is needed to drive the flyback, since a Marx generator doesn't pull much power. Link2
teslacoolguy
Mon Mar 31 2008, 07:11PM
i think if you use a zvs it will charge faster than with a regular 555 driver and if you use -volts to charge it it will charge even faster.
c4r0
Mon Mar 31 2008, 08:31PM
c4r0 Registered Member #151 Joined: Sun Feb 12 2006, 02:53PM
But the marx gen needs rather slow charging...
Mon Mar 31 2008, 08:50PM
...and with the charging resistors the extra current the Mazzilli driver can source will be put to no use anyway.
