  • Guests: 30
Ivan Kalafatic (17)
10/07 Pyromaniac (34)
10/07 Wavetuner (76)
10/07 jeffomatic (75)
ATX PSU question
flannelhead
Sun Mar 30 2008, 07:28AM Print
I thought about modding an ATX PSU for powering small SSTCs. So: lets say the +12V rail can supply 18 amps and the -12V rail 1 amp. If I combine them for 24V, how much current will I be able to draw?
Also another question: would those PSUs have any built-in RFI filter? I mean, those SMPS generate quite a lot of RFI, could there be any kind of filter on the ground side that could be also useful for grounding tesla coils?
Sun Mar 30 2008, 07:30AM
spark wrote ...
The answer is one amp. IIRC there was a thread on SMPS moddins so maybe searching is worth a try.
Sun Mar 30 2008, 10:17AM
Hi peoples
The answer is indeed 1 amp. But I think it would be easy enough to change that. If I remember right how these things work, the -12V comes off the same winding of heavy wire on the transformer as the +12V, but it goes through weedy small diodes and, IIRC, a -12V regulator. On the other hand the +12V goes through a heavy-duty Schottky dual diode, and a winding on the output filter choke (the large yellow toroid with several different wires wound on it)
You could fit bigger diodes, bypass the regulator, and add an extra winding on the output filter choke for your new -12V output, and theoretically get plenty of current at 24V. You'd probably need a good deal of electronics skill to make it work, though.
Yes, SMPS should have RFI filters on both input and output.
flannelhead
Sun Mar 30 2008, 03:46PM
Thanks for answers.
I think it will be easier to hack the PWM for 24V.
Uzzors had something similar on his page: Link2
teslacoolguy
Sun Mar 30 2008, 04:00PM
Steve Conner wrote ...
Hi peoples
Yes Steve you are correct the +12v goes through a heatsinked double diode and the -12v goes through small 1A diodes so what i would do and i actually am going to do this myself is just replace the small diodes with big beefy 6A ones. also i dont see why i would need to put a extra winding on the output choke because they are all the same.
GeordieBoy
Sun Mar 30 2008, 05:10PM
The existing wire for the -12V winding on the buck choke is likely of insufficient thickness to support 6 amps. Remember copper losses are proportional to I-squared. So pushing 6 amps through a winding designed to carry 1, will make it run 36 times hotter.
When you re-wind the -12V buck choke winding, make sure you wind it in the same direction as the original winding. So that it adds to the +12V buck inductance, not cancels it out!
-Richie,
Marko
Sun Mar 30 2008, 06:34PM
I didn't remember ever seeing -12V regulator, -12V is taken from same winding and as you guys said thin wire on the buck choke, then to additional ferrite inductor and filter caps.
In order to get more power you (in most cases I know) need to replace the diodes, the choke winding and output ferrite inductor (which is pretty thin wire to).
I'd advise to replace the electrolytic caps too since ones installed are quite small, and you'll have to replace all caps anyway if you are going to boost the output voltage like Jan.
I've modded an ATX supply like that to output about +-20V, and it works pretty fine except I get odd audible sounds from the supply if I try to regulate the outputs significantly under the rated (+-12V) output voltages at low output powers, like the supply is oscillating, but this done no harm yet. At heavier load (10..15W) it mostly stops, but couldn't get rid of it (tried adjusting the feedback compensation network, shielding the potentiometer leads, reducing potentiometer resistance to minimum and etc.)
Anyone has an idea what causes that?
Marko
Sun Mar 30 2008, 06:49PM
Marko wrote ...
I experience the exact same thing with my bench smps, but I don't know what causes it either. It sounds like ticking/crackling coming from the transformer.
teslacoolguy
Sun Mar 30 2008, 07:26PM
i tried to rewind the choke and it turns out that i can only wind 12 turns of heavier wire than the 20 turns that i removed of the thinner wire and i just wanted to know if this is a problem or not.
GeordieBoy
Sun Mar 30 2008, 10:36PM
SMPSU feedback compensation is a big and complicated subject.
If you try to decrease the regulated output of an ATX power supply by more than 50%, by increasing the amount of voltage feedback, then you will most likely make the control loop oscillate. When you increase the feedback you are not only lowering the setpoint (decreasing the obtained output voltage) but you are also increasing something called loop-gain.
Loop gain is what stabilises the power supply and makes it regulate the output within a tight spec, removing ripple and loading effects, provided its value is right. However if the loop gain is high enough at frequencies where there is sufficient phase-shift around the feedback loop the supply will become unstable and eventually oscillate. (The main cause of the phase shift is the LC filter at the output of the supply.) This usually manifests itself as the output voltage repeatedly slamming between zero and about twice the intended output voltage at some frequency in the kilohertz - Not good, as the overvoltage and high ripple current can sometimes cause marginally rated electrolytics to vent, as well as obviously damaging anything sensitive that the unit is supplying power to.
If you are really interested in this stuff i'd recommend a google search for terms like "buck type III compensation". It is a complicated and messy subject involving bode-plots and gets mathematical very quickly. If you think a "pole" is something that holds up a tent, be prepared for a difficult read. Even for hardened power electronics engineers control loop compensation can still be the cause of some serious head-scratching.
-Richie,
