  • Guests: 39
12/29 Cprossu (40)
12/29 Kokamo (46)
12/29 GalliumMan (60)
What is the fastest projectile speed have you seen from an amateur coil gun.
w1vlf
Thu Mar 27 2008, 03:32PM Print
w1vlf Registered Member #1329 Joined: Mon Feb 18 2008, 07:31PM
Hello Folks,
I am curious what the fastest projectile speed any one has recorded for a coil gun built by an amateur or group.
For example not the military.
Using the projectile drop over distance method, I was able to measure consistantly between 80 to 85 Fps with my single stage 25 gram projectile.
I don't know if this is good or bad, but this is my starting point.
Has anyone every acheived 500 FPS or greater?
PauLC
W1VLF
Bjørn
Thu Mar 27 2008, 04:09PM
The most important measure for coil guns is the efficiency. How much energy ended up as kinetic energy in the projectile compared to what what was in the capacitors to start with.
As the projectile goes faster it becomes more difficult to keep the efficiency high.
The fastest speeds (maybe out of date) are recorded on the forum somewhere but as usual they are impossible to find. If someone finds them then stick them in the wiki.
Electroholic
Thu Mar 27 2008, 06:20PM
I'm pretty sure this is one of the fastest induction guns.
Thu Mar 27 2008, 10:57PM
I'm not up to date on recent results, but I achieved just shy of 100m/s with a 14 gram slug using a six stage (extremely inefficient) 4.7KJ coilgun back in high school.
Had I known then what I know now I'm fairly certain I could have easily surpassed 150m/s (which equates to a respectable 5% efficiency)
There have been a few claims of >200m/s with a reluctance gun, but I don't really know how reliable that is.
Dave
w1vlf
Mon Mar 31 2008, 01:49PM
Dave,
Any chance I could get more info on this CG. I am very interested in a multistage CG
PauLC
W1VLF
Tue Apr 01 2008, 09:15PM
There are a number of old threads about it in the archives.
It was a 6 stage, 4.7KJ SCR switched coilgun. All stages were symmetrical, and were made up of 350v 3700uF general purpose electrolytic capacitors.
The projectile was 1/4" diameter, 2" long and weighed between 10 and 15g depending on which projectile I was shooting.
The barrel was made out of .375" OD, .25" ID delrin tube machined down to .3" OD at the coils.
It was optically triggered, and switched with a large bank of 6 phase control SCRs.
It was a pretty simplistic design overall, which likely contributed to its inefficiency.
EDIT: I found the old thread in the archives. Keep in mind I didn't know half what I do now about coilguns. Quite a bit of the stuff I stated as fact in that thread is wrong in one way or another.
Dave
