  • Guests: 41
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
3 phase vs 2 phase
Thu Mar 27 2008, 01:57PM Print
Let's say I have two wires with a combined resistance of R, and I have three wires with a combined resistance of R. If I run the two wires through a rectifier with a fixed load, and I run the three wires through a 3phase rectifier with the same load, how does the current compare between the two setups? The voltage at the source is the same for both.
Thu Mar 27 2008, 02:59PM
If the loads are identical then the current though the load will be identical (because both sources have the same voltage). The only difference is the 3phase wires will carry less power individualy then the single phase wires.
BTW there are only 3phase, single phase and "split phase" for carrying mains power. Single phase is when you connect your load to 2 hots and "split phase" is when you connect your load to a hot and a neutral.
Thu Mar 27 2008, 06:00PM
Thanks Nik. When I was typing I was thinking of 3 wire and 2 wire.
jk
